Electrical Troubleshooting
Some Other Brand [71 Challenger] car, troubleshooting fun:
Fuel Gage
Assumeframe to batt (-) is ok, all else works.
At tank sending unit terminal 90Ω to frame
Gnd strap across rubber line intact
0Ω tank body to frame.
Wire from car shows ~5V DC, correctfor 71 Dodge’s gages' V. Reg’r.
At dash
VReg shows 12V in, ~5V out to all threegages, pulsed or AC says the consultant
Gages read ~13-15 Ω each one, no wiresattached
Grounding the tank wire makes Fuelgage read full
I surmise this means the sending unit (new, Chinese?) is bad.
TEMP GAGE
similar no reading
grounding wire at engine makes gage peg the needle, so gage and wiring intact.
Probably a idiot lite sender- 1/8 NPT unit.
infinite ohms at room temp, open circuit across the sender.
TACH
THREE wires on coil negative- WTH?
Two are gray
tach should be gray/red
Sending 12V in at dash end gets nothing at coil end. ???
consult manual.
Gray wire should be here at firewall.... EMPTY NEST, no wire there at all.
Aye, aye, aye.
Easy enough fix.
PS they use a BLACK wire for POWER, from alternator, to gages, etc.
Idiocy, that.
Fuel Gage
At dash
TEMP GAGE
similar no reading
TACH
Two are gray
consult manual.
Aye, aye, aye.
Easy enough fix.
Idiocy, that.
Mopars work differently than our Olds's. Scroll down to the middle of the link page.
http://moparfins.com/Repairs/Fuel_Ga...uge_Repair.htm
OK, but, to me, using black for a power wire in automotive applications is just not right.
thanks for the link to the gages issue, will ck that now. I believe we have all three problems nailed, as soon as parts arrive.
Boldsmobile
January 22nd, 2011 01:31 PM
bearls
December 5th, 2006 04:50 AM
bearls
December 2nd, 2006 07:06 PM
Fuzzbeaner
July 9th, 2006 06:26 PM
