Wiring Harness
Wiring Harness
I was in the market for a 70 442 complete wiring harness. I there a prefeffed vendor? I've found 3, since they are all quite expensive I'd like some first hand advice from people who have replaced their harnesses. Thanks
I have used a both M&H Reproduction and also American Autowire. Both are exact reproductions of original wiring. No modification is needed. They are plug and play.
http://www.wiringharness.com/
https://www.americanautowire.com/
Hope this helps.
Hope this helps.
GH Thanks for the input. Ever tried Painless? Looks like they tossed their hat into the ring.
http://www.enginelabs.com/news/new-p...ring-harnesses
Here is another item that I found very useful. Makes life a whole lot easier working with wiring.
https://www.ebay.com/itm/1970-70-Old...hWXarb&vxp=mtr
http://fusickautomotiveproducts.com/
https://www.americanautowire.com/sho...sic-update-kit
I can say first hand that they have great tech support if needed. If this kit were out when I wired my car, I would have used it with no questions asked.
I will also say that I've heard Painless is not as it sounds....
You didn't say if you are looking for direct fit or one you need to customize? If you're looking for Direct Fit, I believe American Auto Wire is the only company that makes one with mini fuses.
I can say first hand that they have great tech support if needed. If this kit were out when I wired my car, I would have used it with no questions asked. I ended up using an AAW universal harness.
