Maxi fuse terminals?
I’m looking for some 8 gauge maxi fuse terminals for a fuse/relay panel I removed from a late 90s-2000 Blazer. I have one terminal in my possession, so I know they are available. I have tried Del City, Electrical Depot, and Waytek, with no luck. I plan to use a 80 amp maxi fuse which should be plenty of capacity.
Anyone in readerland know what the original function/application of this fuse/relay panel? It was mounted below/behind the passenger headlight of a 90s-2000 Blazer
I’m using the relay for the electric fuel pump. The maxi fuse will be a master fuse I pull to cut power to the car. The mini fuse will be wired to supply power to the clocks independent of the maxi fuse.
