I think I may have just killed the wiper motor?
Still continuing the saga of getting the wipers to work again in my '65 Cutlass! Last night I ended up removing the wiper motor from the car and thought it would be a good idea (Hmmmm?) to connect the motor directly to the car battery to see if I could get any joy from the motor.As soon as I did this the spade terminal link cable someone has installed between the middle and bottom terminal started smoking and melting!
Have I killed the motor? As a bit of background I had recently installed an additional tach and thought there was a good chance I had disturbed some wiring under the dash.I have spent a fair bit of time going over things with my multimeter with (I think) pretty weird results at times. For example when I put my meter across the incoming 12v + connector wire and the motor's 3 terminals I got 9.42V on each.I rhought I may be getting this result as there was a connection all the way from the negative side of the battery through earth on the wiper motor and then through the motor itself.Does that make sense?
This testing was done with the ignition and wiper switch both on.Oddly sometimes I couldn't pick up any voltage using the same test.
Disconnecting the battery and resistance testing at the negative/earth connection at the motor and the 12v+ connector wire I got no circuit neither switched or unswitched which seems to debunk what I had thought about a "circuit" through the motor or maybe that's because the motor's windings were not being energized? Any assistance would be great about now!
Available on wildaboutcars.com
Free to join. You can also find them on e-bay used. Someone is selling one on here I believe, and you can get a CD version. Everyone dealing with a old car should have one, even if you don't do your own work. Not many modern shops have mechanics familiar with these cars.
Eureka He Cried
Funny thing is that I already had a log in for the website but didn't know that there was all this stuff there.My previous "access" was limited to me receiving links to original road tests of all of the old muscle cars which are great also.
Professur
April 1st, 2014 07:20 AM
