I need a new alternator
Do any of you knowledgeable Oldsmobile experts know which alternator My 1964 Oldsmobile 98 have been fitted with??
It is the original ext regulated alternator. I have looked for stamped numbers and so, but cant find anything thats tells me what alternator it is. I have looked in the service manual, but cant anything I understand.
I guess RockAuto could supplie a new one together with my new purchase.
Any help is much appriciated.... Thanks
It should be a typical GM 10DN alternator. Reman units normally have smudged, removed, or no stampings like the original units.
Rock Auto has a selection of reman replacements.
Now, if you want a numbers-matching replacement for originality, place a parts wanted ad and see what shows up. I'm sure someone on here has an original application list for your car.
Just out of curiosity, what numbers "match" on an alternator. I'm sure you mean "correct" and proper date code, but unlike VIN derivative stamps that prove originality of a block or trans case, there's no such thing as a "numbers matching" alternator. The difference is that there will be thousands of potentially correct alternators, but only one original numbers matching block.
The 1972 Olds Ninety Eights used a 10DN style (external regulator) alternator rated at 63 amps. It will bolt in place of your current one. RockAuto sells version with a one-groove and a two-groove pulley.
s/match/correct/
442mark
September 30th, 2017 01:06 PM
yeahbuddy
March 6th, 2012 04:22 AM
gearheads78
September 3rd, 2008 11:12 AM
