Generator to CS alternator conversion wiring
Generator on the 56 took a dump. Time for an upgrade. I have a CS130 alt to install. The question is wiring it to the 'Gen' light. Can the field (F) or (L) of the CS be used in place of the OE generator wiring for the indicator light? I plan to run a new 8 GA wire from the CS to the Junction block.
The field or (F) wire needs to hooked up to Ign hot do the alt shuts off and doesnt create a draw. Can this be used for the light or Should the 'L' terminal be used in place of the 'F'? Will just the 'L' hooked up to the 12v light source do the same as the 'f' or field being hooked up to ign hot? I have heard a few ways and get confused. On the 56 , the gen light is fed 12v via key on and used the ground of the charging system when it is not producing voltage. Simply put, the 12v sources cancel and the light goes out.
The only other thing to be aware of is that the CS130 must have a good ground to the rear frame of the alternator. Failure to do so can lead to regulator failure. There is a TSB out on this. If your mounting bracket doesn't bolt to the rear frame, then simply run a ground strap from one of the threaded mounting holes on the back of the alternator to a good ground on the block.
1 small issue. Alternator (alt) is causing a 12.13-12.43V drain causing battery to go low on voltage and unable to start car. Do I have something wired incorrectly?
What we have:
8GA w/ 12ga fuasable link for 'bat' terminal on rear of alt to factory battery/starter junction block on LH fender
16 GA w/ 20ga fuseable link from 'L' pin on alt plug to factory brown 'gen' light wire.
S, F and P pins on alt plug are not being used
Factory voltage regulator has been removed as alt has it own internal regulator. I dont see this being the issue though.
Through testing, it is confirmed alt is causing the draw.
With key off, 'L' pin was jumped with direct ground and had no affect on voltage draw.
Alt does charge properly when in operation
Alt is grounded to engine via mounts. Checked via continuity tester and resistance is negligible.
Gen light flickers per se' w/ key on and engine off. Never goes out but its not a steady light. Light does however goes out as soon a engine starts as it should.
What am I missing here?
What we have:
eddieunderground
August 1st, 2012 02:41 AM
