84 olds cutllass instrument lights problem
All the lights for the turn signals, high beams, check engine light ECT. Its just the illumination lights for the instrument panel and the heater. Every thing works fine except for that. What i need to know is could it be a fuse and how many builbs are on the instrument panel because i could only find 2 and i replaced them. Is it possible its the switch any input would be great thanks.
IDK about the Cutlass, but the Delta from the same time frame had all the dash light on one fuse.
I vote burned out blubs. If so, buy Silverstar blubs. Look great, but expensive at $10 a pair of 194/168 bulbs
Might be 3 behind the speedo, one for each warning light, one for the HVAC controls, and others elsewhere light coursey lights ash tray, etc
