72 cutlass tail light and instrument light issues
Hello. Seeking helpful advice on lighting issues. Yesterday when I had to move my 72 I immediately noticed that my instrument cluster lights were out and the rear lights were out when I put on headlights. The brake lights do go on when pressing brakes. I checked fuse box and all the fuses looked good. Replaced the ones for brake lights and instrument cluster and no change. The signals work. Any suggestions on what to check next.
Thanks,
Andrew
Thanks,
Andrew
Thanks,
Andrew
Thanks,
Andrew
72 cutlass tail light and instrument gaugeissues
Thanks for the notes. One clarification, could the light switch you pull to turn on headlights and rear lights be broken? When I turned dimmer there is no response for instrument cluster. Maybe parts of that switch are bad. I do have a spare headlight switch in my box of extra parts. Figured I would ask first before I remove that switch. Figuring if gauges are not lit and rear lights are out perhaps the switch may be common link. I will check connections as well
cutlass lights
Thanks,
Andrew
Thanks,
Andrew
jensenracing77
December 11th, 2013 08:22 AM
