68 cutlass underhood light.
No 12V power to underhood light in my 68 Cutlass. The light works as it should when connected directly to the battery and all the other stuff on that fuse works.So, is there a connector involved somewhere that I can check? Or is it a bad wire that disappears down somewhere into a huge harness?
Good idea I will try the parking lights/headlights on. I couldn't figure it out from the wiring diagram.Thanks for the help. I'm still learning about this great car.
