Potential rotors for 65'-70' 88/98 disc brakes
Old November 8th, 2018, 02:26 PM
  #41
Delmont1968's Avatar
Doubt you still have these...
Originally Posted by mobileparts
Well, the second guy can be the first guy -- because I still have two (2) and the
"first" guy who PM'ed me never called....
SO... there can still be one (1) lucky winner!!!!!!!!!!!!!!!!!!!!!!!!
Since this is a 3-year old post, I doubt you still have the 67/68 rotors, but thought I would ask.
Delmont1968 is offline
Old November 8th, 2018, 02:27 PM
  #42
Call Craig directly on this. He is only on line sporadically. He routinely gets new stock.
joe_padavano is online now
Old November 8th, 2018, 04:36 PM
  #43
Thanks again, Joe. You have been extremely helpful. Take care!
John
Old November 8th, 2018, 06:41 PM
  #44
matchek's Avatar
I never did buy the Fleetwood rotors because I was able to buy 2 '68 Olds rotors on Ebay from a gentleman's son who cleaned out a GM factory in Canada before it closed down around that time of the post. Craig wanted double.
Speaking of the offset, is the offset different on the Fleetwood rotors for sure of just they might be? Just curious from reading the old threads.
matchek is offline
Old November 9th, 2018, 10:28 AM
  #45
mpolds's Avatar
Delmont 88 --- see you have two threads about these HUB & ROTOR Assemblies -- and I'll answer you here, presently; I already did on the other one seconds ago......
I am not in the library much, as our SUPER moderator Joe Padavano (over 30,000 posts --- halping out the Oldsmobile world repeatedly) points out!!!!!!!!!!!!!!
I DO HAVE those two (2) N.O.S. 1967 - 1968 N.O.S. Original KELSEY - HAYES Front Hub & Rotor Assemblies from the post from 3 & 5 years ago ----- and N.O.S> ++ Asbestos ++ Brake Pads for this application,
as well, such that you don't rip up to smithereens these very valuable Hub & Rotor Assemblies.......
ALWAYS Simply Best to CALL ME ------ Craig -- 516 - 485 - 1935....... and I will tell you some very interesting stories about these rotors & the inquires through the years!!!!!!!!!!!!!!!!!!!!
mpolds is offline
Old July 13th, 2019, 01:57 PM
  #46
68 D88's Avatar
My friend Kevin is finishing my project. 2000 camaro rotors, machined to fit.
68 D88 is offline
Old July 13th, 2019, 02:02 PM
  #47
68 D88's Avatar
68 D88 is offline
Old July 13th, 2019, 02:03 PM
  #48
68 D88's Avatar
68 D88 is offline
Old July 13th, 2019, 02:06 PM
  #49
68 D88's Avatar
68 D88 is offline
Old July 13th, 2019, 02:08 PM
  #50
68 D88's Avatar
A little reverse order never hurt anyone.
68 D88 is offline
Old July 13th, 2019, 07:55 PM
  #51
1968 442 Convertible
bry593's Avatar
Does anyone have the dimensions of the Olds rotor? I don't find these in a quick search of this forum. I see a lot of posts where people say they will measure, but they never post the results. Odd that this important data is completely absent from any discussion?
If you are able, please post the following dimensions:
Outer Dia
Overall height from rotor back to hub face
Hub face thickness
Rotor thickness
Hub hole Dia
bry593 is offline
Old July 14th, 2019, 05:54 AM
  #52
68 D88's Avatar
I don't have the rotors any longer. I do know that the OD of the rotor is 11-7/8", and the rotor thickness is 1.25". The dimensions of the 69 rotor match the dimensions of the 2000 camaro, with exception to hub bore and bolt pattern.
68 D88 is offline
Old July 14th, 2019, 06:20 AM
  #53
You might want to read this thread (which has photos).
The rotors for a 2003-2006 Cadillac CTS with base suspension are actually closer to the OEM 69-70 rotors. The Camaro rotors have a different offset than the OEM rotors, whereas the CTS rotors are the same within a a few thousandths of an inch. I've had a pair of the CTS rotors machined to fit - which simply requires drilling new lug holes and opening up the center bore. They work fine. The Camaro rotors are a better match to the 67-68 full size rotors that use the four piston calipers.
Old July 14th, 2019, 12:17 PM
  #54
bry593's Avatar
So now we know:
OD = 11.88
Rotor Thk = 1.25
Hub Cast ID at MMC = 6.0, Thanks Joe, your link did provide a dimension!
Anyone got a big car wheel lying around? Measure the hub bore and we will have one more piece of the puzzle.
Also need overall rotor height and hub face thickness.
bry593 is offline
Old July 14th, 2019, 05:58 PM
  #55
68 D88's Avatar
Ok, so when I looked the 2000 camaro rotor, it was so damn close to 69, all be that probably 6 years ago when I looked. I recall it being within 1/16 on hub height. With a floating caliper, it'll compensate. Here's some more progression.
68 D88 is offline
Old July 14th, 2019, 06:04 PM
  #56
68 D88's Avatar
68 D88 is offline
Old July 14th, 2019, 06:05 PM
  #57
68 D88's Avatar
68 D88 is offline
Old July 22nd, 2019, 07:27 AM
  #58
68 D88's Avatar
68 D88 is offline
Old August 27th, 2019, 06:26 AM
  #59
68 D88's Avatar
The Delmont is back in service. My friend reports he took her out last night and pounded on the brakes, and has never felt such good brake pedal response. He also used a 71-76 booster and dimpled the fender well for the lines.
68 D88 is offline
Old August 24th, 2021, 12:37 PM
  #60
69od88vert's Avatar
Alright guys, I'm going to try this out on my 69 delta. I'm on rock auto and they list two different diameters for the 2006 base cts rotors. one is a 298mm\12.72" and the other is a 302.7mm\11.92". can anyone confirm which one I should grab?
69od88vert is offline
Old August 24th, 2021, 04:56 PM
  #61
72 Olds CS
RetroRanger's Avatar
post # 54 states
OD = 11.88"
RetroRanger is offline
Old August 24th, 2021, 05:34 PM
  #62
69od88vert's Avatar
post # 54 states
OD = 11.88"
I saw that. So that's the size of the olds rotors so I would need the smaller rotor I'd guess...
Old August 26th, 2021, 10:06 AM
  #63
68 D88's Avatar
Correct, they are 11-7/8 diameter. Also, the rotors that were used in the swap that I have documented are for 2000 Camaro. The finished product has been in service two years now.
68 D88 is offline
Old August 26th, 2021, 04:54 PM
  #64
69od88vert's Avatar
Thank you. I guess i was under the impression, the Camaro rotors were best for 67-68 and CTS was best for 68-70
Old August 27th, 2021, 05:01 AM
  #65
68 D88's Avatar
This build used '69 Delta 88 spindles and caliper brackets with the 2000 camaro rotors.
68 D88 is offline
Old August 27th, 2021, 08:08 AM
  #66
69od88vert's Avatar
Ok thanks I'll post up the results when I'm done!
Old August 28th, 2021, 06:58 AM
  #67
Camaro rotor are the best match for the 67-68 stock rotors, CTS are the best match for the 69-70 stock rotors. The friction surfaces on the Camaro rotors have a slightly different offset from the mounting surface. The reality is that this is much more critical on the 67-68 cars since they use fixed calipers. The sliding calipers on the later cars can accommodate this small dimensional difference. I used the CTS rotors because the one thing you don't know is if the dimensional difference matters at the limits of brake pad wear. Many things work fine under nominal conditions. You need to account for the service limits also if you really want to do proper engineering. See post #22 in this thread.
These photos are a CTS rotor compared to an NOS 69-70 rotor.
Mocephus
October 1st, 2021 09:45 AM
rcdynamic88
Brakes/Hydraulic Systems
May 5th, 2016 08:36 PM
russell7088
32
May 1st, 2012 12:15 PM
akins2000
January 26th, 2012 02:42 PM
Wilson05
October 24th, 2009 03:29 PM
Quick Reply: Potential rotors for 65'-70' 88/98 disc brakes
