My 79 delta 88 royale
#41
#42
thanks, yes, that is true, hehe cool,where did you get that from? mine, i build it from standard 1.2l engine and driveline to 2.0 driveline,ls diff, and 2.2cih engine,welded on fenders from vw golf 1 and much more.. im not finish with that car yet ..but here is some photos how it looks like now.
very nice!!! I got mine from a friend of my ex girlfriends dad. mine was a coupe with the original 2.0E Rallye engine and metalflake paint.
was very cool to drive!
#45
cool,hmm is it headlights from bmw or manta A? i want a cupe, city and caravan too, i have a caravan before but i sold it cause i want the oldsmobile,and i need space for it here im now.
here is a little videoclip from last i use my kadett, lol, not so much power, just standard 2.2e engine, now i have begin to dissasemle the head, i have another one that will go on the engineblock soon,its a little tuned.
http://s251.photobucket.com/user/Fas...65eba.mp4.html
have this setup i will install soon.
#46
I'm not sure , but I think the headlights were from a BMW E30. I bought the car like it is on the pictures and I never liked these headlights...
Your setup looks very good!
#47
I noticed it, and meant to ask you earlier, but got distracted...
Did you lower the car or was it like that when you got it?
If you did lower it, how did you get it down???
I love the progress. If there's anything you need or are looking for, don't hesitate to ask. I've collected quite a few parts for these girls. I am working on a 78 Holiday 88. Feels good to have someone else saving one too!!
#48
Anyway i use only 225/60/15" wheels in front and 275/60/15" wheels in rear so it looks a little lower in front maybe.
Do you have a link to your project tread of your holiday88?
Well i will try to find a orginal steeringwheel that kan fit this car,,maybe it fits from other types too.
#49
I have not lower it, but it looks like it is, but i can`t see if the front springs on my delta88 is cut off,they look orginal, i don`t know what older users of this car have done too,maybe the springs are just old and lower by self ,hmm.. the suspension is very soft too with new shocks in front.
The front definitely is lowered somehow. If they were worn that low, it'd have zero ride quality. I run 235/65R15's on mine. I want to bring mine down slightly.
Currently what is in mine are the stock 78 350 springs. I plan on pulling and replacing them with 78 403 springs.
Sadly, I do not have a link to a build thread... I can list what's done. It's a long list so far. I can say, I don't think there is anything I haven't touched yet!
#50
So springs from 78 delta 88 with 403 engine is lower than 78 350 springs?
i want to install 235/65 or 70 / 15" tires in front,, cause if i use a tire calculator 235/70/15 will match the 275/60/15" wheelsize. ..i will try someday.. cause the frame under the engine is very low, maybe 10cm to the ground
#51
Nice project. You are doing a ton of work. Can't wait to see it finished.
My second car was a 1979 delta 88 2 door with a 301 2bbl. Great car but slow. It was a very reliable car. I added rear stabilizer bar, polyurethane bushings, and gas shocks. Car handled very well. I will try to find some pics to upload.
#52
Yes maybe, maybe someone have install springs from another car too,,i don`t know,,the springs is very thick, it`s difficult to see if someone have cut them too..
I stand corrected. My tires are 235/60 R15's. I went with them because based on the original tire size, these were closest. I didn't want the speed-o to be all wrong. I also wanted a tire print that was wide and grippy.
#54
78 403 Heavy Duty springs are not any lower, the rates on them are stiffer. I want to take some of the pillow like ride out. I play a little with Autocross, and have a blast at doing it.
#55
Not so very much happend this time.. cant remember what was the last update? well just for fun i install some stickers and new gearbullet.. i got the 225/70/15 fronttires to match the dim on rear tires 275/60/15" the car been more confirtable to drive,now i can lean back in the seat instead that i follow down in front with 225/60 front tires hehe..
Im in progress to build up a garage/mechanic house for my cars, so then my delta can have roof all the time and i can begin to take out windows and other things..im thinking to split the chassie from the frame too and overhaul it all.
Maybe i should paint it pink, loll
#56
Some pics of the new engine that will come,1968 400G block with C heads, ported, balanced and polished crank,rods and pistons,0.03" overbored,new bearings and rings all around,new pistons,overhauled valveseats etc,so its good as new inside...but not so beautifull on the outside, lol, mds ignition, msd disturbutor. edelbrock 2151 intake, edelbrock carburetor (not sure yet how big)..
381.1 Hp on 5000rpm and 596.7Nm (= 438.8 lb-ft on 3750rpm)
So i think this engine will be a ok option in my big cruiser
The engine have stand still some years so i need to check over the oil sump gasket,and after that installing new oil and filters,and flush the system. I will replace the valve covers with some one higher i think..and other color to match the edelbrock intake.... or should i paint the engine like the 307 blue one??
Some headers, im not sure if they will fit, or i will make them fit
And some pics of my other project, maybe not so interesting for guys on a V8 forum, building a new engine to it.. a 2.0l 16v (c20xe) 150hp 196nm orginaly.. later i will replace to low comp piston and build turbo on it for maybe around 350-400hp in the engine.
Now its:
*Honed block
*H-rods
*Underflushing oil needles for piston cooling
*heavy duty oilpump gear
*new pistonrings
later it will be bored from 86mm to 86.5mm
and install low comp pistons and other stuff for turbos....lol...
Old engine
new engine
ignition system that will be used Megajolt
painted block,valvecover etc
Before dissasembeling the block
after
piston cleaning and monted on rods
doing ring gap ready
Now its:
*Honed block
*H-rods
*new pistonrings
Old engine
new engine
after
#58
This evening i have cleaning a litte around and make space for the engine and parts that will come..
i go out after and took some pics.. long time i have see inside the car now.. lol.. .. looks like the roof will fall down soon,but it will not. i want to take it out and make a new one.
#62
Picked up some parts today for the new engine.
edelbrock 750cfm...
"750 CFM, MANUAL CHOKE
(CALIBRATED FOR PERFORMANCE)
Designed and calibrated for optimum street performance in small-block and big-block engines with Performer RPM, RPM Air-Gap and Torker II manifolds and with Performer manifolds on large cubic-inch engines. Includes both timed and full vacuum ports for ignition advance. Electric choke #1478 can be added if needed. Comes with: Metering Jets - Primary .113, Secondary .107; Metering Rods - .071 x .047; Step-Up Spring - orange (5" Hg). Use Carb Studs #8008 or #8024 if needed."
MSD ignition, used 1 time, when the engine was tuned up, i have coil and starter too..
I dont know yet if these headers will fit..i will try..
New gaskets,oilfilters ,magnetic plug and engine mounts
edelbrock 750cfm...
#63
Polished and painting
For dobble exhaust..
#65
Oh,why? Will it to be much ignition? Im not sure what the box will help for, can i use it without the box?
Is it better to use a hei disturbur? I have a new for olds engine in my part collection if so. it stands on the msd box i need some special cables if i understand it right.
#66
MSD ignition question
I have a New (used one time) disturbutor, coil and this msd Box,, on the Box it stands i cant use that type of cables, what cable should i use? is it ok to use this ignition system on a dailydrive/street engine?
what is the meaning of this Box? make the ignition signal stronger?
i have a New HEI disturbutor too, that i buy for my old 307 engine but i have never use it,, why it is not coil and a Box With that?
#68
I moved your other question back to this thread. Any 8mm ignition wire set that is for a stock Hei will work. I like Taylor Spiro-pro wires. The MSD box is over kill for your application and as I mentioned earlier in another post, all your doing is adding another item that has the potential to fail into your ignition system. The Hei that you have will work very well without it.
#69
Hmm ok, so this msd parts is ignitionsystem for racing setup or something? I cant even use the msd disturbutor alone? I see it should be connected to the box so maybe not.
But i guess the msd box is Worth something? Should i sell it with the disturbutor,box and the coil?
#70
Sorry my mistake on the distributor, I did not look at the picture close enough. Is there a tag on it that shows the part number? You may be able to use it independantly of the MSD box. You will probably still need a coil that seems to be in the backround of another photo. I don't see a vacuum advance on the distributor?
#71
I have the disturbutor nr: 8566 another design on it on the link below.
http://www.msdignition.com/Products/...stributor.aspx
Im read about it now, i see i cant us it without the msd box.. its no vacum on it.
yeah i have the rigth coil Blaster 2, thats follow with the msd box.
I found the manual on internet now too.
But im not sure anyway if i can use this setup, im not sure what sparks are in the new engine right now,i know it is just a standard disturbator standing in the engine now with some sparkplugs, i have not study it what type or brand.
thanks
if i understands right its just an ignition that makes its stronger and more stable? i found a video on youtube, it was a huge diffrents... well this type is analog design and not digital too.. it have a external rev limit chip outside, i have not check what it is yet. i will see...
#72
I would use your current distributor and sell the MSD system. Its meant for a more performance setup. You won't see any change with your engine with this system compared to what you have already and in fact your fuel economy will probably be worse for the lack of vacuum advance. All the other stuff you got will work fine.
#73
I see, well i guess you have right, maybe the ignition system was used only when the engine was tuned in to see how much hp and tq it will delivier, i hope someone other can use the setup then, but maybe its hard to sell in my country,since this is for olds engine. but i will try if some are intrested..
here is specs from HEI i boght new,
- 50,000V High output Ignition coil
- High Performance module
- Brass Bushings
- Adjustable Vacuum advance
- Brass Terminals
- Chromoly Steel Gear
- E-Z 1 wire hook up
- For use up to 7000 RPM
#75
- Brass Bushings
- Brass Terminals
#76
i think i will just keep the msd kit, my friend who doing v8 tuning/racing told me i can use it too on a dayli driver machine too,he told its just a ignition setup that will deliver good power without other problems, im not sure about the fuel use if it use more, and after much google it looks like a nice ignition opinion to use.. and the diffrent between standard disturbutor and msd ignition is huge. (now i have not see how the HEI ignition deliver but i guess its good too)
BUT, for fun im thinking to just hook it up on my lazy 307ci that will soon be replaced, to see how it will act on the engine,and if it will use more fuel or something i will use the HEI disturbutor with vacum, if it will work ok i can use the msd on the new engine i guess,, but i will try the HEI disturbutor first on the new engine was my plan, so im waiting to sell something yet before i have try it
just want to experience it,is my point
I dont know,but maybe the HEI disturbutor with that specs is close or even better than the old analog msd ignition, i see it have rev limit to 7000rpm and the MSD have rev limit 6000rpm. lol
