Rear sway bar
Rear sway bar
I'm looking to add a rear sway bar to my 1978 Delta 88 Holiday coupe. Any recommendations? Will any B-body sway bar work? My local salvage yard has several 1990's Buick Roadmasters in it. Will one of those work? I think that there's a 1985(?) Caprice in the yard, also. If it has a bar will it work? Or... should I just get an aftermarket one? Any suggestions?
Thanks.
Thanks.
Thanks.
Thanks.
Yesterday I just scored a rear sway bar, mounting brackets, and lower control arms. The bar is 1" in diameter. All are in excellent condition. I sanded and painted the sway bar, but just cleaned up the arms. I'll install them within the next week or so when the weather is a little warmer. It's only been in the low 20s this week but is expected to warm up to the mid 40s next week.
I was able to install the lower control arms and sway bar the other day. While I was at it I replaced the rear shocks. The shocks on the car were the original spiral ones from the factory! I saved the original parts. The bar looks good and it should help in the handling department,
Jim,
I don't think I'll be adding dual exhaust anytime soon, if at all. The exhaust system looks like it may be fairly new. Plus, a previous owner removed the cat and put a straight pipe in its place at some point. I'm sure that alone has freed up a few HP.
Here's a picture of the underside.
