Coil springs for a 61?
Old August 14th, 2018, 11:50 AM
Sydwaiz's Avatar
I'm looking to replace the coils on my new to me 61. The previous owner cut the fronts and pinched the back so the car sit's pretty low right now and the front wheels rub at full lock. I like it low just not maybe this low!
Has anyone bought springs from Eaton Detroit Springs? If so, were you satisfied with them? I see they offer springs for my application and up to 2" drop. I can either buy from them or I've found some on Rockauto.com that I could buy and cut a little at a time to my liking. One of the problems is I don't know what stock height is compared to where it sits now. Anyone have suggestions or advice? Thanks!
Sydwaiz is offline
Old August 14th, 2018, 03:48 PM
Phantom Phixer
Charlie Jones's Avatar
This is from the 1961 Oldsmobile Shop Manual ;
As you can see , the specified height is a range . And anything within that range was considered "acceptable" .
" Curb load " was the basic weight of the car , without passengers or luggage .
Charlie Jones is online now
Old August 14th, 2018, 09:40 PM
Eaton was an original supplier to GM for springs.
1969w3155 is offline
Old August 15th, 2018, 06:33 AM
Proud Viet Nam Veteran
redoldsman's Avatar
It sat a little too low in the front for my taste. Good luck on your springs.
redoldsman is online now
Old August 15th, 2018, 07:41 AM
Sydwaiz's Avatar
Thanks for the spec sheet. Now to get it on a rack or over a pit to get under and measure. As of right now, the frame is only 2-3 inches off the ground in the front. I'm already going to have to buy a new low profile jack just to get under it.
I knew Eaton was the supplier. I guess my question was more about their lowered offerings. They upcharge and don't accept returns on their modified springs. Looks like i'm going to gamble and be the guinea pig!
Sydwaiz is offline
442oldz71
April 28th, 2018 10:35 AM
dschallock
Suspension & Handling
30
September 15th, 2016 04:42 PM
Williamaronson
May 1st, 2016 08:42 AM
olds68442
August 9th, 2015 03:50 PM
dhartley72
August 7th, 2010 08:28 AM
Quick Reply: Coil springs for a 61?
