72 Delta 88 radio removal
Unless you have small hands and skinny arms you'll have trouble getting to the support bracket from beneath the dash. Aggravating as it is, you need to remove the lower dash assembly to get to that bracket. After that, remove the RH pod and the radio will come out from the front. Shop manual helps.
Great thing is aftermarket units are light and usually don't require putting the rear support bracket back.
