Leaking gas tank at bottom 74 olds
Any suggestions on stuff to use to repair a leaking gas tank its not a whole more like a crack of some sort or maybe a pin whole? Besides buying a new tank for now I want to fix it.
Clean it well, and it will probably work best with the gas OUT of the tank (no pressure pushing against your repair). Also, taper the edges of the putty and smooth them into the surrounding surface.
will do my mechanic knows a place that cleans and welds them but at this point i just want a simple fix when i get the car paitned ill take it off and have it done thank you...
defiant1
March 16th, 2015 09:44 AM
