Gas Tank leak / replace or patch? Thoughts?
Hi all,
I just discovered a small pin hole leak in my gas tank. (72 Delta 88)
So should I try patching with JB Water Weld, anyone have any personal experience with this stuff?
I know I should just replace it. Patching is a temporary fix, and if there's one hole, there a hundred. BUT will the JB patch buy me a few months?
Thoughts?
Thanks,
Kensey
Pittsburgh, PA
Thoughts?
Thanks,
Kensey
Pittsburgh, PA
If it's a small hole this should solve your problem.
https://www.summitracing.com/parts/poi-49239/overview/
You can also buy them from Eastwoods and Amazon. Just make sure you wear PPE. It's nasty stuff!
You can JB Weld patch just about anything. I've got a JB Weld epoxy patch on a grease trap in one of my restaurant kitchens that has been holding for, oh, 3 years now? If JB Weld had been around 100+ year ago, I'm pretty sure they could have limped the Titanic back to shore and I'd never have to see that damn movie on cable ever again.
I digress, My way of thinking...if you gotta drop the tank...for probably less than 150 bucks you can get a new tank, I'd just pony up and replace it...unless there is a sentimental attachment to the tank for some reason.
Just my .02. YMMV.
Cheers,
Troy
Just my .02. YMMV.
Cheers,
Troy
If you can get a tank at all, I think it will be more than $150. You should be able to get it cleaned and sealed by a radiator shop for about $150. The kit from Summit that Olds64 mentioned would be another option if you are up to it. There has to be rust in the tank and it needs to be cleaned out. Be sure and change the sock on the pickup if you drop the tank.
Just plugging in 1972 Oldsmobile Delta 88 fuel tank into my intrawebs search engine yielded a few hits such as this...
https://www.stockwiseauto.com/spectr...f1990608f2262&
Now, I don't believe everything on the intrawebs as 100% factual but I think it would be worth the OP's while to investigate. If no such animal exists, then you don't have much choice but to repair it......
Just my .02, YMMV.
Cheers,
Troy
Just my .02, YMMV.
Cheers,
Troy
I have encapsulated leaking tanks in fiberglass. In one case I know it worked for at least seven years with UK unleaded gas.
Not in ideal solution for a show car, but it does work.
Roger.
Roger.
When my 72 Cutlass started leaking back in 89 I had the tank repaired at a radiator shop. The held just fine till I replaced in in 2012. Cost less and worked just fine. Spectra premium is a good tank though if you want to go new. I'd take out the old one first and evaluate whether it's just one small hole, or the potential is there for a lot of them.
I got some two part epoxy putty from NAPA years ago and it stopped the leak while the gas dripped from it! It comes in two sticks that you cut chunks off and squish together and smash onto the leak. It was cheap easy and lasted forever
rockauto list wagon tank. 71 and 72 full size 88 and 98 sedan and coupe tanks are like cutlas tank but bigger. i have yet to find someone making them. used tank, have yours fixed or some sort of custom tank are the only options.
