85 Delta 88 Hoses Questions
Old November 20th, 2008, 07:58 PM
whizkid88's Avatar
Hey does anybody know anything about the hoses on the stock 307? Virtually all of the hoses are dry-rotted and I am currently replacing them. Any suggestions would be helpful. Thanks.
whizkid88 is offline
Old November 20th, 2008, 09:38 PM
Seasoned beater pilot.
J-(Chicago)'s Avatar
Just do them 1 at a time and use the correct sizes, and you'll be fine.
J-(Chicago) is offline
Old November 20th, 2008, 10:14 PM
Just A BaBy {:
easytobedead's Avatar
yea if your not familiar with the 307 then take it 1 at a time. an for the coolint hoses i believe they have a nice setup for them thats not just a plain hose but i don't member what it is.
easytobedead is offline
Old November 21st, 2008, 06:09 AM
You should be able to get them at your local auto parts store. Like the others said, do them one at a time and you should be fine.
Olds64 is online now
Old November 21st, 2008, 07:55 AM
Lady72nRob71's Avatar
One more tip is to use ONLY gentle pulling and twisting. If the hose seems really stuck, use a razor knife to slit the hose at the nipple and peel it off.
The worst thing is breaking a $75 part to replace a 50 cent hose.
My neighbor did worse on an acura by breaking a connection off the cruise servo. However, he superglued it back on right before he traded it.
Lady72nRob71 is offline
Old November 21st, 2008, 07:15 PM
Redog's Avatar
Yeah agreeing with everybody else.
The hoses are probably dry rotted away after 20+ years in the heat. I forget the sizes of the vacuum hoses but there is only 3 different sizes. The important lines are for the secondarys on the carb.
The coolant hoses, don't know the size of the upper and lower hoses, but your autoparts store will have them in stock by hoses by model of car, and the heater core hoses. One goes from the water pump to the core, the other goes from the core to the heater control valve in the back corner of the manifold. The one size is 3/4 inch and I think the other is 5/8.
Use WD-40 on the heater core brass to ease on the hoses, these break really easy, and push the hose on as far as it will go, but use the hose clamp on the tip of the core lines, there's a hump on there for the clamps
Redog is offline
Old November 23rd, 2008, 07:09 PM
whizkid88's Avatar
I just got done and it runs like a new car. Thanks for all the tips. They helped and yes they were all originals and it was a massive pain but it was well worth it.
7244too
March 5th, 2009 02:55 PM
Iragh
November 17th, 2008 03:41 PM
relic
February 23rd, 2008 04:43 AM
Redog
December 29th, 2007 09:13 AM
dynamic371
March 1st, 2007 12:57 PM
Quick Reply: 85 Delta 88 Hoses Questions
