1980-1985 Oldsmobile delta 88 and regency 98 owners
Old January 30th, 2017, 12:08 PM
  #121
btw
Smokin' BBQ Member
btw's Avatar
Big Oldsmobile comfort can't be beat! Built for highway cruising! Before the Delta, it was the Delmont and before that, the Dynamic. ALL GREAT CARS!
btw is offline
Old February 8th, 2017, 03:16 PM
  #122
deltsanddueces's Avatar
I just bought this one owner 85 delta 88 royals brougham in September, only 67000 miles but it needs alittle work from sitting, I replaced the radiator and trans cooler lines, I also did the front struts and springs. when the weather breaks I plan on tuning it up (original spark plugs, yikes) and doin the rear springs and struts
deltsanddueces is offline
Old February 8th, 2017, 08:48 PM
  #123
golden rocket
golden rocket's Avatar
https://oklahomacity.craigslist.org/cto/5973316014.html
don't usually put somebodys' for sale on. I can't seem to recall this body style. doesn't look to bad, sort of dressed up. I have worked on the small v-8 and they were pretty gutless, but awful thirsty.
golden rocket is offline
Old February 8th, 2017, 11:14 PM
  #124
Oldsdelta455's Avatar
That's pretty nice! I never cared for the slant back cuttys. I think 78 and 79 were the only years for them.
Oldsdelta455 is offline
Old June 10th, 2017, 05:12 AM
  #125
Phil-29's Avatar
Hi,
this is my 1984 Oldsmobile Delta 88 coupe Royale Brougham.
I bought it in France a few months after it came from Florida in 2007.
It has 105.000 miles and pretty good condition. Just need to replace the intake manifold gasket because of a coolant leak.
A few pics:
The first day i saw it (in France), still with its Florida plate:
Blue interior:
With great light:
At the gas station:
Facebook Post
Downtown:
Facebook Post
Near the Atlantic Ocean, west France, with a few mates:
Facebook Post
Full album:
Facebook Post
And this is my photograph page:
Facebook Post
Phil-29 is offline
Old June 12th, 2017, 03:01 PM
  #126
golden rocket
Only way to have an Olds, with all the options. real clean looking, too.
Old June 12th, 2017, 07:51 PM
  #127
Out of Line, Everytime😉
olds 307 and 403's Avatar
Other than their large size, they were/are a great car. My 88 G body is a POS compared to the 81 Delta 88, I owned. The Delta out handled it big time and had better wiring, heat etc, the list goes on. Our First Nations up here drove the 80's Delta's into the ground. Very little maintenance and no oil changes, they still went a lot of miles, only the occasional timing chain on the 307's for major work. Great cars.
olds 307 and 403 is offline
Old June 13th, 2017, 07:24 AM
  #128
Philippe, thanks for sharing those pics!
Olds64 is online now
Old June 13th, 2017, 01:16 PM
  #129
gkhashem's Avatar
Originally Posted by 80holiday88
After I took the original hubcaps off for safe keeping and threw on a set of dog dish Olds caps for the fun of it.
You do know that's one rare car.
gkhashem is offline
Old June 13th, 2017, 01:23 PM
  #130
gkhashem's Avatar
1984 Delta 88 Royale Brougham Coupe
I bought it 6 years ago with 23,350 miles. Now has 28,200 and usage declining each year. I have too many cars.
I even have 2 NOS moldings left and right for the belt that divides the vinyl top from the paint. Those later years cars all fall apart. I need to replace them soon.
All stock even still has ice cold R-12.
gkhashem is offline
Old July 12th, 2017, 08:03 AM
  #131
Wauktown847
Wauktown847's Avatar
It's cool to see so many old Deltas alive. Here's my 84 with 78,000 original.
Wauktown847 is offline
Old July 12th, 2017, 08:05 AM
  #132
Wauktown847
84...
Old July 15th, 2017, 08:52 AM
  #133
SooKrazyMamaof7's Avatar
Can anyone tell me what model car parts are interchangeable with a 84 delta 88 royale brougham 2 door? I am trying to help my 16yr old son fix up his 1st car. It has a 307... Won't stay running. Before it died if driven at a steady speed of 45mph or higher for 10 mins or so it would seem as if it was flooded... Getting too much or not enough gas. Afterwards it would start if we poured gas into the thingy but now it won't. Replaced fuel filter. Any suggestions? After the mechanical part is safe I want to help him with cosmetics the car is in really good condition considering it's age that's why I asked about what other models are interchangeable? So I can call junk yards... Thank you soo much!
SooKrazyMamaof7 is offline
Old July 16th, 2017, 12:09 PM
  #134
80-84 olds 98 and Most G body or B body Buick, Olds or Pontiac from 81-85 with a V8 will have an olds 307
Old July 16th, 2017, 12:27 PM
  #135
Thank you for the reply. Could you tell me what G body and B body means? Also what year and model cars are interchangeable with body parts? Like doors and seats etc... Thank you SOOO much.
Old July 16th, 2017, 12:52 PM
  #136
jcdynamic88's Avatar
mostly 80-85 delta 88,some 98 parts 80-84. G body refers to cutlass models
jcdynamic88 is offline
Old July 16th, 2017, 01:37 PM
  #137
body parts are gonna limit u to delta 88's and 98's mostly G body's refer to the cutlass, Regal and Grand Prix b body's are bigger models like the lasabre and Bonneville
Old July 16th, 2017, 01:55 PM
  #138
Olds Collector
vistacruiser1971's Avatar
Another item to consider is the timing chain in your 307. Olds put plastic gears as the teeth of the chain which wear off and cause weird things before the engine stops at some point. Do you have records on your son's 307 to see if this was done? Mine went out at 150,000 miles. That was years ago and age might have a factor as well. It might be a good lesson for your son to help you with a timing chain replacement to make sure it is done if you don't have mechanical records. If you do this, pull the harmonic balancer with a puller secured in the holes toward the center of the balancer not from the edges. You will pull the outer balancer ring off and ruin the unit. Check youtube for step by step instructions there are many good tips available on line. I wish you the best with Father and Son project. Regards, Trent in Los Angeles
vistacruiser1971 is offline
Old July 17th, 2017, 03:04 PM
  #139
Thank you so much for replying. I am trying to find a manufacturer manual online now. I was told to start there. Actually this is a mother son project 😀 I'm not going to give up til I figure this out. I truly appreciate all the help I've received here
Old July 27th, 2017, 07:01 AM
  #140
MyOldsMan's Avatar
I have a 1984 Olds Delta 88 Two-Door that I am thinking about selling... Need advise on how to list it ?....Thanks. (I am new to this, & I am unfamiliar with how it works)
MyOldsMan is offline
Old July 27th, 2017, 10:21 AM
  #141
Olds Collector
It is easy. Log in and navigate Forums/Classified/Cars For Sale, the upper left corner has a button "New Thread", press it. You will have a blank screen to enter your title and text about the car. Toward the bottom there is a "Go Advanced" button, press it. You will then have a pop up screen on the left that will allow you to search your computer for photos. The more photos the better. Press upload and at the bottom of that window close the pop up. Back toward the original screen with the ad will be a Post Quick Reply button, press it like you did the your ad question post above. Easy. Regards, Trent in Los Angeles
PS: Make sure you post your location.
Last edited by vistacruiser1971; July 27th, 2017 at 10:22 AM. Reason: Location request
Old September 21st, 2017, 05:34 AM
  #142
Royale Brougham w/ Cheese
UMMM NAH's Avatar
Hey all,
Time for pictures ... this is my new 85 Olds Delta 88 Royale Brougham. Grampa fresh! This will be my new daily driver. Plans for the car include checking the 307 timing chain, replace if necessary; AC repair; lowering; and a nice stereo.
Last edited by UMMM NAH; September 21st, 2017 at 05:47 AM. Reason: bigger pictures
UMMM NAH is offline
Old September 21st, 2017, 10:41 AM
  #143
that 85 is beautiful, btw i have taken apart those roller lifter 307s with 170k miles and the timing chain was fine.nothing like the older v8s with the flat tappets
Old September 21st, 2017, 10:42 AM
  #144
UMMM NAH's Avatar
Thanks, good info to have. I read about the nylon in the timing chain sometimes coming apart, and I got nervous. I still plan to just pop the fuel pump out and check chain tension.
UMMM NAH is offline
Old September 21st, 2017, 12:59 PM
  #145
MyOldsMan's Avatar
Nice Olds, Pappi ! Really like it. (I HAVE THE TWO-DOOR VERSION, & IT WILL BE UP FOR SALE SOON !) If anybody wants pixs of it, Please E-mail Me at ThomasMargoG@aol.com
Old September 21st, 2017, 05:17 PM
  #146
golden rocket
85 is a really good looking body style, Olds had it for a number of years. Dad had as he called it "an 88 88" coupe, that came with what appeared to be ground effects on it. I think it was a 3.8 V-6 but he could pull 30 M.P.G. highway driving down to Florida for the winter. Car was loaded with all the options, but I don't remember a sun roof on it. white with a red interior. I've been looking for one like it, since he passed back in '07, but haven't come across one. Dad traded it off after the tin worm started having dinner on it, and got a Cierra sedan, and despised it. I told him he should have stayed with a full sized or Cutlass model.
Old October 11th, 2017, 05:36 PM
  #147
Jack Heffler's Avatar
Really like the wheel covers with the black center
Jack
Jack Heffler is offline
Old October 11th, 2017, 05:39 PM
  #148
Sweet ride......
Old April 1st, 2018, 10:21 PM
  #149
Olds Collector
Hello Mr Ummm: Beautiful car. Nice color. I suspect paint work since some emblems look to be in the wrong places. I really like the color and condition of the interior. The seats look new and very comfortable!! I would check the timing chain for sure. I think all the Olds V8's had the plastic coated cam gear which can break apart. I am not sure you can confirm if it has been replaced by just pulling the fuel pump. I think the timing cover should be pulled. I wonder if you have records from the previous owner to see if the chain was replaced? My .02 cents would be not to lower the car. It won't ride as well and the lowered frame has a risk of hitting a curb, speed bump, driveway, or the wheel stops they put in parking lots. I have a car with just such damage and it is a bit of a pain to fix the problems. Take care of that sweet ride. Regards, Trent in Los Angeles
Old April 2nd, 2018, 05:39 AM
  #150
MyOldsMan's Avatar
Olds Delta 88/ 84 Olds Cutlass Calais 2-door for sale
I guess I'll add 2 more cents giving You four cents on what VistaCruiser71 already posted. I agree with Him. If it is not broken, Don't fix it. Lowering & adding too many aftermarket add-on's can actually "detract" from the value. Originality is King ! You have an excellent car with unusual options, like the sunroof top ! I would get the mechanical's fixed & keep the change ~! Thanks
I have a slammin' 84 Olds Cutlass 2-Dr that is for sale with an after-market 350 Cu.In.....It is a barn-burner ! For any additional info, Please let me know.
Old April 2nd, 2018, 06:43 AM
  #151
Olds Collector
Here are my additional .02 cents about having a way loaded car and keeping it original. You have the popular options, windows/locks/tilt/cruise and the split front seat - great. Even the right mirror is usual for an 85. However, you are very lucky to have factory gauges. They are great to have to monitor the V8. Now you are at .06 cents! Regards, Trent in Los Angeles
Old April 3rd, 2018, 06:32 PM
  #152
Forward into the Past
Human's Avatar
Originally Posted by quaddriver
That 84 looks like it shares a few body parts with my 78...
Yeah, that body style ran from 1977 to 1984 on the Ninety-Eight, until 1985 on the Eighty-Eight, and all the way up to 1990 on the Custom Cruiser. The roofline on the Ninety-Eight changed significantly starting in 1980, becoming much more formal looking. The ones from the late '70s were more like the Eighty-Eights had throughout that period.
Human is offline
Old February 13th, 2019, 09:28 AM
  #153
RoyaleBrougham88's Avatar
Everyone’s Delta looks really good I must say! I own an 84 Delta 88 Royale Brougham, picked it up for $180 and drove it on the trailer! Cleaned it up and here we are. It has 108000 miles on it but still runs strong, I absolutely love everything about this car and all other deltas. Big plans in the future like a 400+ swap and 7004r swap for big power. Right now it’s not the most rust free car but I hope to change that when I get a good money cushion in the bank.
RoyaleBrougham88 is offline
Old February 14th, 2019, 06:47 PM
  #154
83Delta88's Avatar
1983 delta 88 royale
Just wanted to introduce myself here and share a few pics.... I'm the recent owner of a 1983 delta 88.... now 117k miles and I have owned it for about 4 months.
83Delta88 is offline
Old August 28th, 2019, 01:23 PM
  #155
anyone got 2 door parts?
Old August 28th, 2019, 03:51 PM
  #156
Wauktown847
Selling my 84 Coupe.
2350
Oakdale California
Old June 17th, 2020, 09:31 PM
  #157
The Stickman's Avatar
Thought I might share my 1983 Master Oldsmobile hearse built off an Olds 98 sedan. This company literally made 2 of these cars and went out of business. This is number one. It's in rough shape but pretty easy fixes for most stuff.
The Stickman is offline
Old June 30th, 2020, 11:50 AM
  #158
elpelon's Avatar
Originally Posted by henryk8398
After replacing rear filler panels:
Wow those wheel skirts look great! Where did you source those?
elpelon is offline
Old June 30th, 2020, 01:46 PM
  #159
skirts were factory on 80-84 98s
Old January 26th, 2021, 07:16 AM
  #160
Destructor's Avatar
I fondly remember those Delta's, unfortunately when it came to replacing my 88 Caprice LS I couldn't find any 80's Delta 88's in the Boston area that weren't rusted out. That was in the early 2000's
Destructor is offline
Quick Reply: 1980-1985 Oldsmobile delta 88 and regency 98 owners
