1966 Delta 88 power steering pulley
Old June 19th, 2016, 10:42 AM
bnanna922's Avatar
Any tricks to getting this pulley off to install a new pump?
bnanna922 is offline
Old June 19th, 2016, 10:50 AM
The 66 pump uses a nut and key on the pulley. I've found that leaving the belt tensioned helps getting the nut loose. You'll likely still find the pulley is a tight fit and will need a puller of some kind.
joe_padavano is offline
Old June 19th, 2016, 10:55 AM
bnanna922's Avatar
So the nut is off, but the pulley is really on there and I don't see a place to grab the puller on.
Old June 19th, 2016, 12:48 PM
Yep. Do not try to grab the O.D. of the pulley with a multi-jaw puller.
Do NOT ask my how I know this...
Soaking the shaft and pulley with penetrating oil will help. Heat on the pulley will help, but you will likely damage the front seal on the pump.
Old June 19th, 2016, 11:52 PM
bnanna922's Avatar
Is it hard to find a replacement pulley? I may just caught the old one off, but I am having trouble finding a part number.
Old August 13th, 2016, 09:09 AM
Larry/car's Avatar
Cut the end of the shaft flush with the pulley, now using a drill press, drill the shaft out of the pulley (pilot drill, then using larger drills till you can tap the remaining shaft from the pulley. I have used this method with good results.
Larry/car is offline
68Tom
October 24th, 2010 07:55 PM
Steve Wike
August 22nd, 2010 06:45 PM
msco123
March 9th, 2010 10:13 AM
oldsonharmont
Suspension & Handling
February 9th, 2010 06:35 PM
mcutlass1969
March 26th, 2007 07:09 AM
Quick Reply: 1966 Delta 88 power steering pulley
