1953 88
need assistance in removing rear drive shaft--way different than my 442--got bolts off can get driveshaft to drop --also need rear pinon seal replaced and trans rear seal --any pics would help--not sure if this has olds tranny or buick due to the fire at hydomatic plant
I will try to look up a seal number. I am sure there are guys here with books that might be faster than me. Jim
J D
I kind of think the 53 had straps across the universal joint that bolt to the yoke on the differential. If not it has u-bolts. In either event, remove those and then take a large screwdriver or pry bar and put between the universal joint and the differential and pry against the ujoint. it should come loose.
olds53rocket
December 22nd, 2006 05:46 PM
<jdhideaway@aol.com>
Brakes/Hydraulic Systems
March 31st, 2005 08:15 PM
