Rookies-Pinion Angle quest...helpl!
Old January 22nd, 2011, 04:40 AM
STLCRZY's Avatar
Hy,
anyone can say me how much i must change rear end pinion to come to the correct streetable operation angle.
Found a few sites on web where explain everything about pinion drive angles but i´m not sure if understand everything correct because...my lack of English.I´m a little confused and maybe it´s a stupid question but i wanted to be 100% sure, so please take a look at the pic and let me know.(but speak slowly for euro guys )
Current Set up= Rear 3°up and Trans 3,5°down = +0,5° correct?
I would need -2to3° negative drive working angles correct?
So how much and in which direction (up-down) must i change the rear.
Must i subtract the rear measurements from the trans measurements or contrariwise?
Thanks for help.
STLCRZY is offline
Old January 22nd, 2011, 04:54 AM
STLCRZY's Avatar
forgot the pic...
STLCRZY is offline
Old January 22nd, 2011, 05:08 AM
car guy
gearheads78's Avatar
What are you doing to need to change anything? Have you raised or lowered the car a bunch? What you are showing is drive line angle. Unless you are drag racing you don't need to be messing with the pinion angle either. Explain a little more of what you are trying to do.
gearheads78 is offline
Old January 22nd, 2011, 06:48 AM
STLCRZY's Avatar
I don´t want to race or change height for now,only want to set the pinion angle correct to prevent vibration noise.
Can i stay with this angles?
STLCRZY is offline
L77F85
October 1st, 2013 07:16 AM
boese1978
April 26th, 2012 09:41 AM
Al2011
August 18th, 2011 06:46 PM
STLCRZY
Brakes/Hydraulic Systems
February 9th, 2011 03:21 AM
78cutlass
March 6th, 2009 07:39 AM
Quick Reply: Rookies-Pinion Angle quest...helpl!
