Drive shaft yoke
Old March 5th, 2019, 06:14 PM
rick442's Avatar
Drive shaft yoke
My rear transmission seal is leaking after replacing it. Does this distance look ok? I'm just wondering if it is too long and may be moving too much.
rick442 is offline
Old March 6th, 2019, 05:22 AM
SmirchIs#1's Avatar
What I have seen from taking apart and working on hundreds of muscle cars for 40+ years,the norm seems to be 3" of yoke engagement with the output shaft.If your yoke has 3.5" of useable surface,as many of the muscle cars had,then you're only in 1.5" which is not good.This will cause excessive ocilation at the "U" joint.This situation can cause a vibration and even cause the tail housing to brake on a hard launch.It will at least cause premature bushing wear.If this is coupled with a already worn bushing in the tail housing,then the seal could leak and the previous cond. described is greatly amplified.Also I notice there seams to be a lot of dirt or something present if the seal was just replaced.The seal and area must be clean,grease the seal groove and make sure the lip spring is in place.Careful when instaling
SmirchIs#1 is offline
Oldssupreme
August 3rd, 2016 06:12 PM
davoaz
August 23rd, 2015 07:47 AM
craftsmen22
Drivetrain/Differentials
July 30th, 2014 05:47 AM
jRoofgunner
February 18th, 2014 07:12 AM
at3reg98
July 7th, 2012 12:49 AM
Quick Reply: Drive shaft yoke
