Rear end id help
Rear end id help
I have been looking all morning but I cannot find any info about my rear. It is from my 69 442 convertible. I cannot find a 2 letter code. Here is what is on the front passenger tube:
The engine and trans were not original. They were both late 70s. Would not be surprised if it was also swapped.
here are the only other numbers i can find, and the whole axle.
thanks,
bob
thanks,
bob
Chevy 10 bolt 8.2 rear
Housing casting date G 30 1
1971 year (1 )
day 30th (30)
July month (G 7th month)
GNC ( 3.08 ratio ) 224 (224th day of the year) August 12, 1971 (Thu) 1 (1st shift)
No Posi
28 spline c-clip axle rear
Normally found in a chevelle, Monte carlo or Elcamino
Jim
J D
1971 year (1 )
day 30th (30)
No Posi
Jim
J D
1310 yoke 1970 -1972 New style Chevy.
That is all the info for you.
Chevy 8.2 10 bolt fits all 1968-1972 A-body GM direct to chevy or with u-joint conversion yoke with BOP... 1971 1972 Buick and olds will need a drive shaft lengthening.
J D
Jim
J D
Jim
Brakes
Also riveted and bonded shoes.
It sounds like you just want to get on the road and have some fun though so - call around for pricing all hardware kits are the same 65-72 if you can not find any of that instock
1995-2004 S-10 brakes will also bolt right up. If you can not wait for some one to order up the chevelle brakes.
Shoes, Wheel cylinder hardware kit l r adjuster kits 95-2004 will bolt right up to the a-body f body 9.5 x 2 backing plates. DO not mix and match s-10 to chevelle brake parts though use totally one or the other parts list.
Good luck, Jim
J D
monzaz
October 26th, 2020 07:08 PM
