Gear ratio on a posi
Old October 24th, 2018, 08:52 AM
RoyaleBrougham88's Avatar
I obviously own an 84 Oldsmobile Delta 88, it’s got a 307 with a 4 speed auto, and a posi rear end. I was attempting to do some research but I guess my car isn’t really common or something, so I couldn’t find anything in the rear differential gear ratio. I found the transmission ratios but no differential ratios. Any help would help me
RoyaleBrougham88 is offline
Old October 24th, 2018, 09:34 AM
Does that year vehicle have an RPO sticker somewhere, such as in the trunk? If so, it should have that info.
Fun71 is offline
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
Count the number of tire revolutions to drive shaft revolutions. That will get you in the ball park. Pull the cover and look at the ratio stamped into the ring gear. Probably could use a rear gear service any how. Likely a high 2 or low 3 series.
droldsmorland is online now
Old November 18th, 2018, 04:42 AM
78Cutlass4Speed's Avatar
According to the 1984 Dealer album, 2.73's were the standard gear set for the Delta 88 with the 307 V8 and 4-speed overdrive transmission. 3.08's and 3.23's were optional (with the HD cooling) except in California. High altitude cars got 3.23's standard. As Fun71 said, there should be an RPO sticker (most likely in the trunk on the lid) with all of the codes on it.
GU2 = 2.73
GU4 = 3.08
GU5 = 3.23
G80 = limited slip (posi)
78Cutlass4Speed is offline
Old November 18th, 2018, 11:05 AM
Just looked at it has two codes on it, GU2 and G80. So I’m assuming that it has 2.73 gears and limited slip right? I know for a fact it’s posi though
Old November 18th, 2018, 11:15 AM
Yes, correct. It is a 2.73 posi.
Old November 18th, 2018, 11:18 AM
Got it thanks for the help!
jmos4
June 5th, 2018 05:32 PM
Mikey_mick
May 10th, 2017 07:17 AM
bigdooly
Drivetrain/Differentials
May 22nd, 2015 05:03 AM
White_Knuckles
March 23rd, 2014 10:38 AM
65Delta88
20
January 14th, 2009 07:15 PM
Quick Reply: Gear ratio on a posi
