High speed driveline vibration
Any ideas on why I am getting a high speed drive line vibration when I let off the throttle at speeds over 70mph on my 66 442. U-joints are good and properly installed. I tried changing the orientation of the driveshaft with the rear end with no change. There is no vibration when accelerating or cruising, just when I let off at higher speeds and no difference if I push the clutch in or shift to neutral. Thanks Jim.
papsmac
March 2nd, 2016 05:19 PM
