Will this work in my 71
Old April 9th, 2018, 08:47 AM
Photoshop God
DewChugr's Avatar
Will this posi work in my 71 10 bolt? Not interested in 410s.
https://i.imgur.com/usggbCn.png
DewChugr is offline
Old April 9th, 2018, 01:14 PM
Gerald Nickels's Avatar
Are you going to race it ? If not 3.42 are what you need for performance.
Gerald Nickels is offline
Old April 9th, 2018, 01:39 PM
If it is in fact for an 8.5" 28 spline rear, then yes, it will work in your 71 8.5" 10 bolt rear. I can't see any casting numbers in the picture so I can't confirm it is the correct one.
Fun71 is offline
Old April 9th, 2018, 01:51 PM
What Kenneth said.
I put 3.42:1 in my posi 8.5 and I'm wondering if I shouldn't have gone with 3.08 or 3.23 instead.
Don't forget that if you do decide to change your gear ratio, you will also need to change your drive and driven gear at the transmission end. Both are easy to change, although the drive gear is a little on the messy side since you need to remove the prop shaft and tailshaft to access it.
Allan R is offline
Old April 9th, 2018, 02:03 PM
Photoshop God
DewChugr's Avatar
Originally Posted by Allan R
What Kenneth said.
im only interested in the limited slip which I'll try to get numbers on. The trans is not an issue .
https://imgur.com/a/l98F9
DewChugr is offline
Old April 9th, 2018, 02:07 PM
Your link didn't work as it should. https://imgur.com/a/l98F9
Allan R is offline
Old April 9th, 2018, 04:41 PM
monzaz's Avatar
posi unit
Yes that will fit fine... It is a 8.5...The pinion shaft is the dead giveaway.
Go grab it looks like an original Eaton Positraction unit. you can rebuild it too even if the clutches are worn out. Jim
JD Race
monzaz is offline
smkn600ctd
December 29th, 2014 05:38 PM
tex70
December 18th, 2006 12:59 PM
CHRISD
August 29th, 2006 01:23 PM
daverbmxer
May 30th, 2006 05:35 PM
Jaked
September 3rd, 2004 04:45 AM
Quick Reply: Will this work in my 71
