1967 CS Holiday Coupe Drive Shaft
Hey guys,
I figured you would enjoy this story. I have a 1967 CS Holiday Coupe that I am in the middle of attempting to make a daily driver. My latest issue has been no speedometer. I found out that the speedometer drive gear was toast, so I ordered a new one. Then I found out that the worm gear was no longer being held in place properly. This is when I decided to take it to a transmission shop because I have no lift. The transmission shop is now telling me that the reason the worm and drive gear were buggered up is that my drive shaft was too long! SO now I am waiting for the drive shaft to be shortened. However, I can't help but wonder..... How does a 50 year old car shrink or a drive shaft grow? It has been hit in the trunk but I see no evidence of frame damage/warping.
Good theory. Although the transmission shop is telling me that the drive shaft needs to be shortened. So, what do I look for as far as problems once I start driving with the shortened shaft? I want to be able to blame the transmission shop if I start seeing drive line issues once they have shortened the shaft.
There should be about 3/4 inch gap between the transmission seal and the part of the yoke where the ujoint is installed. Are the rear end or control arm bushings worn out allowing it to move forward?
There's another option - the trans shop is full of manure.
Note that the speedo drive gear is well forward of the forward end of the splines. Someone please tell me how the yoke can move that far forward - unless the driveshaft has some non-original yoke with a looooong section forward of the splines. I've never seen that.
This is easy enough to test. Temporarily remove the tailhousing. Slide the yoke onto the output shaft and see if it is even possible to contact the speedo drive gear. Methinks you have unnecessarily (and incorrectly) shortened the driveshaft.
The only possible way the driveshaft could be "too long" is if the car originally had a Type O axle and the axle had been replaced with a Chevy axle. The Chevy axles have the pinion flange about 1" further forward from the axle centerline than does the Type O and thus the driveshaft would need to be about an inch shorter. That still doesn't explain how the yoke moved forward of the splines on the output shaft.
theory
Here is a theory someone broke the drive shaft (u-joint etc.) and had to replace it to drive the car and they got a junk yard one and put it in there. REMEMBER - not everyone is going to take the car to the shop or just repair what needs to be done. ...QUOTE ' Oh well a buddy got me it for FREE!!!!! ' end quote lol.
OR the transmission is not original to the car... or the rear is not original to the car...GOD it could be anything....
Vehicles this old especially MUSCLE CAR ERA cars are notorious for all kinds of junk getting thrown in.
YOU should see some stuff we get in that people have put together or shops have installed in rears. Parts that do not even belong in rears...lol 8.2 parts in 8.5 rear wrong series carriers and gear sets??? It is insane...
You better set aside some more money cause it is going to keep on rolling...lol.
Jim
J D
Jim
J D
The Cutlass is Back Home
I got the car back on Friday, they were able to fix the gears that drive he speedometer. However, they were also able to prove that with the suspension in full travel, the end of the drive shaft did indeed impact the worm gear. I now have a shortened drive shaft, new U Joints, and a new set of gears, and a speedometer that works. The folks that shortened the drive shaft said that it was a GM shaft from the correct period but that they expect it was from a larger car than a Cutlass.
70convert
Drivetrain/Differentials
March 7th, 2019 02:12 PM
64 CUTLASS KEN
November 22nd, 2010 05:17 PM
