Value of #672 31 spline differential and 3.91 R&P ?
Old December 30th, 2017, 10:45 AM
GEARMAN69's Avatar
Curious of market value , #672 31 spline differential with or without oem 3.91 gears
GEARMAN69 is offline
Old December 30th, 2017, 09:52 PM
Apologies for the add on, but if anyone needs a housing and axle shafts to go with these let me know. I have a 68 HD 31 spline TL code 31 spline rear wasting away behind the garage that would make a great companion to the gears and posi carrier.
Fun71 is offline
Old December 31st, 2017, 05:20 AM
GEARMAN69's Avatar
I have one 31 spline axle and the TO housing minus the brackets had been cut off for A body and had leaf perches added.
Old December 31st, 2017, 08:26 AM
rktolds's Avatar
pm sent
rktolds is offline
Old December 31st, 2017, 10:23 AM
Magna86's Avatar
You can have the perches rewelded on and it would be fine unless they really butchered it. Fun71 pm sent
Magna86 is offline
Old December 31st, 2017, 11:04 AM
MOTORHEAD
11971four4two's Avatar
[QUOTE=GEARMAN69;1065188]I have one 31 spline axle and the TO housing minus the brackets had been cut off for A body and lead perches added.[/QUOTE
HI
The posi unit and gears in good condition are worth maybe $400 - $700 depending on how nice they are.
A butchered housing is a liability and will cost $$$ to repair or replace missing parts , if it is salvageable at all. It will never be worth what a nice unmolested piece would be.
All the best
11971four4two is online now
Old December 31st, 2017, 11:45 AM
GEARMAN69's Avatar
Thanks y'all, I need to get home and get stuff clean up. Will decide what to do soon. PM also if you have a 671 unit
Old December 31st, 2017, 12:01 PM
MOTORHEAD
I have a complete SD 3.08 12 bolt rear end back plate 2 backing plate
Too bad you are not close by
We could do a trade possibly
With cash coming my way
Old January 7th, 2018, 06:19 PM
70442rag's Avatar
I do have a 68' heavy duty 12 bolts Olds posi that was rebuilt last summer sitting in my garage. It does have factory 3:91 gears in it w a brand new GM clutch pack, seals, bearings etc. It is the rare 31 spline rear end offered in 1968 and is the 672 carrier. i have two of them and would be willing to part with one. The housing is in nice shape and already painted a semi gloss black- ready to be installed. if interested please send me a PM to discuss.
Thanks.
70442rag is offline
Old January 8th, 2018, 03:56 PM
GEARMAN69's Avatar
Gears have some rust but no sign of wear issues, no sharp edge. Factory set. The one 31 spline axle looks fine. I believe the deal was someone busted the other axle when it was being used last in the leaf spring car it was modified for and it got pulled apart but unable to locate a stock axle to repair it.
Old January 8th, 2018, 04:08 PM
GEARMAN69's Avatar
Pics from today. And now that I see them blown up bigger on PC looks like I got a small corner chip on a pinion tooth. I may keep all this stuff. Will see.
rktolds
June 1st, 2015 06:38 AM
Bob Kelso
July 24th, 2013 12:32 PM
sbFALL63
Drivetrain/Differentials
March 23rd, 2011 03:08 PM
sbFALL63
March 23rd, 2011 02:23 PM
Quick Reply: Value of #672 31 spline differential and 3.91 R&P ?
