Spider gears for open 8.2 BOP Diff
Old July 15th, 2017, 05:13 PM
Kalle's Avatar
Hi guys.
I just worded on my car, and i found that the Spider gears in the Carrier are worn out.
Ring an pinion are fine... excellent wear pattern an no play in them but you really feel (and see them moving) the worn out spiders if you turn the Pinion by hand.
Does anyone know a shop who has these in stock..?
I only found 8.2 GM Spider gears online.
Jan
Kalle is offline
Old July 20th, 2017, 02:20 PM
Kalle's Avatar
Kalle is offline
Old July 20th, 2017, 04:08 PM
72 Olds CS
RetroRanger's Avatar
try sending a PM to monzaz his business specializes in rear ends
RetroRanger is offline
Old July 20th, 2017, 10:58 PM
Ozzie's Avatar
Be sure to check the differential cross shaft for wear also.
Ozzie is offline
Old July 26th, 2017, 11:32 PM
monzaz's Avatar
Originally Posted by Kalle
Hi guys.
Jan
JAn, Need more info for the correct parts to be found. YOUR not going to get NEW spiders as they are not reproduced...but we might have very good used gm used gears here with low mileage. need to see the other sides of the carrier and you should disassemble the carrier you have and see if all the thrust washers are in the and behind your gears as this will cause the loose fitment in a carrier.
will need to know the cossshaft size .733 or .795
Jim
J D Race
monzaz is offline
Old July 30th, 2017, 03:26 PM
Kalle's Avatar
Jim
J D Race
Hi Jim,
Thanks for your help. Used parts in good condition are fine for me. IŽll dig into the rear end in a couple weeks. Have to fix the chassis first. I will send you pictures.
Do you think i have to change the axle bearings too ? Is it recommended ?
Kalle is offline
Old August 1st, 2017, 02:30 PM
monzaz's Avatar
Hi Jim,
Changing the bearings is usually a mileage thing or in a case where you do not know how many miles are on the rear... OR if you find bearings worn out galling etc. the races will usually indicate issues. Jim
J D Race
monzaz is offline
73aussie455
Drivetrain/Differentials
23
May 12th, 2017 05:33 PM
sammy
January 13th, 2016 10:48 AM
Napoleon1991
January 18th, 2013 07:06 AM
goatwgn
December 28th, 2012 08:28 AM
Bluemeanie
Non-Olds Engines
May 3rd, 2012 04:06 PM
Quick Reply: Spider gears for open 8.2 BOP Diff
