70 Ring gear question
If you have it open to count the ring gear teeth, it is very easy to turn the gear to see the numbers stamped in the edge of the ring gear. That will have the number of teeth on the ring gear and the pinion gear. Divide the two numbers for the ratio.
Or, count the teeth on the pinion and do the math.
oldspackrat
August 10th, 2014 10:03 PM
costpenn
May 10th, 2013 06:11 AM
fabcraft
November 12th, 2011 11:15 PM
idaholc
April 13th, 2009 01:33 PM
