75 h/o posi rear axle
I just picked up a 75 H/O posi rear axle. I assume it's a 8.5. What ratio are these normally? Where is the axle code located? Are these desirable and what price do they bring? I also have the lower rear control arms and the sway bar. Thanks for any info provided.
Mike
Mike
Actually
DIFFERENTIAL
Seen as a quick fix to fuel mileage issues, ultra-high rear gears were the fashion of the day in the mid- to late 1970s. Thus, the Hurst/Olds rear axle came standard with 2.56 gears and could be optioned up only to 2.73 or 3.08 gears, with or without the Anti-Spin limited-slip differential. Look on the front side of the right axle tube for a six-digit code; the first letter of that code will indicate whether it's an open (code A) or limited-slip (code C) differential, while the second will indicate the gear ratio (H for 2.56, C for 2.73, and D for 3.08).
Hope this helps Ya.
As far as value, its all in the need of the buyer.
Regards, Brett
DIFFERENTIAL
Hope this helps Ya.
Regards, Brett
Actually
DIFFERENTIAL
Hope this helps Ya.
Regards, Brett
DIFFERENTIAL
Hope this helps Ya.
Regards, Brett
10 bolt 8.5
You can up grade that rear to be very strong...10 bolt 8.5 corp rears are great.
MANY many parts and you can get any gear ratio under the sun. 2.24 - 5.57
Posis true trac eaton auburn detroit locker power trax full spool
J D RAce
J D RAce
Mike
warrior71
February 28th, 2014 07:52 AM
507OLDS
April 2nd, 2013 11:18 AM
507OLDS
September 11th, 2011 07:37 PM
