Rear end help!
Rear end help!
I have a 72 Cutlass. Need info on this rear end. 8.2 or 8.5? Planning on putting a posi on it soon but my local shop charges me 1300. I think if i can figure out what i need and what i have, i can probably get it done cheaper. Any help would be appreciated!
Check with one of these guys
Monzaz = Jim Mitschke
J D Race & Restoration
Muscle Car Differential Specialists
Richfield, Oh
507OLDS
Brian Trick
Erie,PA
thetrickfamily@yahoo.com
814-440-3553
Both of them are specialists with rear suspensions and drives.
Richfield, Oh
507OLDS
Brian Trick
Erie,PA
814-440-3553
ID rear
1971 1972 Cutlass 8.5 10 bolt rear - Bolt in axles
A9 axle bearings with 712146 seals
28 spline axle shafts
SA 2.73 ratio NON POSI standard open rear one wheel peel.
Hope this helps. Jim
I have parts if you need a quote...Might save you some money on parts anyway. Jim
JD
JD
I need help guys! So i ordered the package above from ebay. I messaged the guy and told him they were for a 72 cutlass with 8.5 rear end. He messages me back and ask me if im sure its an 8.5 and not an 8.2. So i tell him im sure its an 8.5 and gave him this info
1972 Cutlass 8.5 10 bolt rear - Bolt in axles A9 axle bearings with 712146 seals 28 spline axle shafts
Then he replies with this...
This is the correct package as long as you are 100% sure it is an 8.5. The pinion should have 30 splines. Thanks..
What do you guys think? Is it going to fit?
I bought my posi from Jim. I have a 72 8.5 corporate 10 bolt. Axle splines are 28, pinion is 30, gears are 3:23
So yours should fit.
Looking for this to be done in the summer.
I'm going to be very happy with the 3:23's whether I like them or not! FWIW I did think about 3:08s and 3:42s. For what I want do do with the car though 3:23's are the answer. I'll use more gas, but so what? It's not like this is a daily driver. If it was I'd just keep the 2:73s on the posi.
Well at least you're happy. I just parted out my 72, which I put a Chevy 12 bolt in with 3:73 which I pieced together back in the day. It was way to much for what I want today. Really debating between the 3:08's or 3:23's as a final ratio. Whether I use that rear end, or put a posi in the one in the car, it is at least a 12 bolt cover. I'll admit thought I still confused about the 8.2 and 8.5 inch and whether its an O rear end or corp. I need to take some pictures and send to the rear end guys. So I know what my options are.
350TurBRO
September 12th, 2014 11:52 AM
MDchanic
31
August 12th, 2012 04:24 AM
