Original 72 rear axle bearings and retainer plates vs. different looking new ones??
The replacements i just bought for my 72 cutlass supreme 350 have a bearing and a "lock ring" which basically looks like a solid bearing without the *****, so to speak. Is this supposed to take the place of my inner retainer plate which resembles more of a collar with a flange to the inside? If so, Do i remove and throw away this retainer plate and replace it with the new lock ring? I have seen other posts which appear to do just this, but i want to make sure.
Thanks!
Chris
Thanks!
Chris
Yes, the new design lock ring is a thick collar as compared the thinner stamped original lock ring. You should end up with axle retainer flange, axle seal, bearing, and lock ring.
This pic from http://www.supercarsunlimited.com/in...id/diff_id.htm shows the factory style lock ring:
Oldssupreme
July 31st, 2014 07:58 PM
HWYSTR455
Drivetrain/Differentials
28
December 25th, 2011 11:55 AM
oldzy
September 14th, 2010 05:40 AM
