Help to Identity a 10 bolt rear end
hey guys trying identify the rear end on my car, I was told it was replaced from original.
Car is a 1976 cutlass s 442 and the rear end is a 10 bolt with a stamp on it that reads, CK 135. Thanks for the help
rear end iD
10 bolt 8.5 ID
Yes it is a 8.5 - Not really the cover I am looking at... You can put a CHEVY cover onto an 8.5 ...it fits perfectly.
You have the 1st pictures cover on the second pictures housings...BUT still it is a 8.5 no matter which way you slice it.
Look at the 5 and 7 o'clock area of th e casting. The cat ears hanging out the bottom... Then the brake like will have a cast in boss with a tapped hole for the brake line to be bolted to the casting top between the upper control arm boss mounts.
Yoke will have a 1 1/4 diameter bolt holding the yoke on. the yoke will have 4 bolts and 2 steel arched straps holding the u-joint in and the u-joint cups will be 1 1/8". 10 bolt cover and 10 bolt ring . ALL A-body 8.5 will have these things...
Jim
J D Race
Jim
J D Race
Look at th e 5 and 7 o'clock area of th e casting. The cat ears hanging out the bottom... Then the brake like will have a cast in boss with a tapped hole for the brake line to be bolted to the casting top between the upper control arm boss mounts.
Jim
J d RAce
Jim
J d RAce
twilightblue28A
Drivetrain/Differentials
April 9th, 2016 07:13 AM
