help! i want to change to a posi 3.42.
I have the peg leg 12 bolt "o" rear in my 68. I want to know the best, most cost effective way to change it over to a posi 3.42. Is there an axle I can find in a junk yard to swap over? I would rather find a posi rear with the wrong gears and get new gears for it? Posi units are not cheap. Any help would be great. Thanks
I have a 3.42 posi carrier and the ring and pinion for a 12 bolt O axle that I bought from supercarsunlimited and had it in my SX for about 50 miles and replaced it with a 2.56 posi carrier that I bought from JD Race.
If interested please send me a PM.
Yes,you "could" buy a posi rear,with the wrong gears,maybe get a deal,but by the time you get the new gears installed,and the smoke clears,you will have the same into it.Not to mention,the posi unit itself is over 40 years old,and probably needs some attention.No matter how you cut it,you will end up spending the same amount on the rear.
Thanks for all of your help. If I cant get sworthy's unit then I will just buy new. I think that is the smartest route to take here. I don't like doing things more than once if I can avoid it. dave
what cars have that 12 bolt
i was wondering what year cars have the 12 bolt chevy rear in them? It isn't too expensive to have the driveshaft shortened. gears and posi units are pretty expensive. If I can find a used one with lower miles that might work?
BIGJOESX
Drivetrain/Differentials
June 3rd, 2008 02:04 PM
