geezer gasser turn on your PM
Hey Jim need to send back the PM you sent with info but your PM is turned off.
Here is the message I sent
hEY jIM, iF YOU CAN SEND SOME PICTURES OF THE REAR and if you have pictures of the axles ... If you have a 69-70 pontiac rear as you say...the A9 bearing and 712146 seal should be the one you need. Jim
But before buying anything we should double check the rear ID. I am assuming it is a a-body pontiac rear?
you can call 330 659 7117 also we can discuss stuff. Jim also
