1972 Cutlass Yoke and Driveshaft issue
Hello All,
I have a 1972 Cutlass S that I am in the process of converting to a manual. I have an M21 Muncie 4 speed that i am putting in the car. It came with a yoke that was for a 71 Camaro which does not fit my driveshaft. If I purchase a 32 spline yoke for a 72 cutlass, will it fit my drive shaft? The transmission I removed is a TH350 so the driveshaft length it correct but I want to confirm that the yoke will fit the U-Joint before I purchase the wrong part.
Thanks for the help!
I thought the M21 and M22 used the 32 and the M20 used the 27? The guy I bought it from said it was an M21 from a 1971 Camaro. Would the Camaro's 32 spline yoke be the same as an Olds 32 spline yoke? I know the Camaro in that year was an f-body and my cutlass is an a-body.
So I guess I have an M21 with M22 gears? Its the same length as my existing transmission exactly. Either way, will the yoke for a 32 spline fit the U-Joint for a TH350 driveshaft or are the holes for the bearings a different size?
M21 and M22 have the same gear ratios. Apparently the difference in yoke size is due to the year of the trans. Late Muncies (mid-70s) got the large output shaft, same as the TH400. You'll need an Oldsmobile yoke for a 3R U-joint. The one from a TH400 will be the same.
One other thing to know, the auto trans cars used a 2 peice shaft. Those shafts have been shown to slip over time. Standard shift cars used a 1 piece shaft. You may be a couple dollars ahead to have a new shaft w correct for your trans yoke made now!
Precision "U" joint # 372 I use a lot fore your prob.Also as stated all 71'-74' Muncies have the large output,with one exception being the 70" Chevelle LS6 which also had large yoke.You should also know that all 71'-74' Muncies are 3/4" longer than 63'-70' Muncies.I don't know what trans. you had originaly,but if it was anything other than a TH400 short tail,then your shaft won't work,it will bottom out.Also some th400 yokes are too long for the Muncie & can hit the speedo drive gear.You want to shoot for minimum of 3" yoke/shaft spline engagement
71cutlass350
Drivetrain/Differentials
16
November 16th, 2019 08:09 PM
