1969 Cutlass Supreme cowl tag decoding help
Old April 30th, 2014, 12:17 PM
starhyde's Avatar
I have owned my 69 Cutlass Supreme Holiday Coupe since 1987. She got me into alot of trouble as a teenager. I was hoping that you all might be able to help me to decode the cowl tag? I know the car was made in Fremont, CA, but that's about it so far. The VIN is 342879Z129237
starhyde is offline
Old April 30th, 2014, 12:49 PM
dnmfranco's Avatar
built in Fremont Cali 5th week in April
exterior color Topaz
interior I think Gold bench not positive
dnmfranco is offline
Old April 30th, 2014, 12:53 PM
dnmfranco's Avatar
oh digits after z are build sequence
342879= 3 olds division, 4287 supreme model, and 9 year
Old April 30th, 2014, 12:57 PM
starhyde's Avatar
It has bucket seats with a factory console. All of the interior is still gold. I bought it from a little old lady who had been the original owner.
Any idea about the numbers on the third row, after the build date code?
starhyde is offline
Old April 30th, 2014, 01:11 PM
dnmfranco's Avatar
okay pretty sure it was gold
b-80 drip rail moldings
numbers after build date not sure
Old April 30th, 2014, 01:18 PM
Randy C.
rcorrigan5's Avatar
ST 69 = style/model year = 1969
34287:
3 = GM division = Oldsmobile
42 = model series = Cutlass Supreme
87 = body type = holiday coupe
BF = assembly plant = Fremont, CA
06478 BDY = Fisher body number (has absolutely no relation to the VIN)
TR 974 - interior color and front seat type = gold interior with bucket seats
B80 = exterior drip scalp molding
65 65 PNT = lower & upper body colors, respectively = topaz
04E = time build code = April (04), fifth week of that month (E), 1969
The other numbers are codes that perhaps others can answer but I do not know what they are!
Your VIN: 342879Z129237
The front part of it (34287) is as described above. the "9" is the model year (1969), the Z is the assembly plant code (Fremont, CA), and the remaining digits are the plant seuential number (i.e., theoretically, the first A body to roll off the assembly line was 100001, then 100002, and so forth. I have a '69 4-4-2 that rolled off that same Fremont line a few weeks after your car did (05C time build code) and its plant seuential number is 131299, or 2062 cars later.
Randy C.
rcorrigan5 is offline
Old April 30th, 2014, 01:45 PM
starhyde's Avatar
I am hoping that I will wind up finding the build sheet as I work on it. At this time, I don't intend on restoring the car, but rather just trying to get it back on the road. Several years ago, I took out the back seat, looking for the build sheet to no avail. Probably wind up dropping the tank and see if it might be stuffed up there. I appreciate the info that you have provided.
starhyde is offline
Old September 28th, 2023, 02:44 PM
Kenny_69OLDS's Avatar
Can someone help me decode this ??
Can someone help me decode this tag.. I was told it might possibly be a W-30..
Kenny_69OLDS is offline
Old September 28th, 2023, 02:54 PM
Please create a separate NEW thread rather than piggybacking on a thread which is nine years old. You'll receive more PERTINENT assistance to YOUR cowl tag rather than a COWL tag which doesn't belong to you.
EDIT: Can you provide a BETTER image than the one you posted or at a minimum provide the EXACT numbers on the plate. We shouldn't have to GUESS. You should do the preliminary work.
Vintage Chief is offline
Old September 28th, 2023, 02:56 PM
ok
Oldsmobile Joe1
February 10th, 2023 07:29 PM
A67olds
September 30th, 2022 11:18 AM
P516
August 11th, 2021 09:26 AM
starhyde
February 12th, 2019 06:45 AM
Browndogs
December 6th, 2016 06:01 AM
Quick Reply: 1969 Cutlass Supreme cowl tag decoding help
