72 cutlass
Yes. If it was factory there would be a letter U in the vin tag. There's another member here named 72455 who has one of these cars. You might check with him if you think yours might be one too. He can share what to look for on your car. John
Yep..I'm the guy he's talking about. Thanks to the contributions from various members here and doing a lot in my own, I've learned a lot about my 72 Supreme, so if you need any help or info, I'll see what I can do.😀
Here's a couple pics of mine...
Thanks for all your help guys. A friend of mine has 72 supreme with a 455 in it and we were trying to find out if indeed that eng was available in a cutlass for 72. I’m relatively new here. I recently purchased a 64 F85 with a 455 in it. I’m sure I will need some help in the future! Thanks again for all your help.
Be aware that back in the 70s and 80s it was common to swap a 455 in place of a 350. No one cared about originality back then, and for gearheads looking for more power a 455 swap was a no brainer.
For factory 455 in 1972 Cutlass Supreme Codes are ...... Letter in VIN
U = 455 with TH400 auto transmission
V = 455 with M20 4 speed manual transmission VERY FEW OF THESE WERE MADE
X = 455 "442 W-30" NOT a Cutlass Supreme
Interesting JOE
All the HO 72 hardtops I have seen are U code in the VIN
Were the X code ones TH400 auto trans or were there 4 speed ones as well???
I hope you take advantage of every opportunity to enjoy it, cuz I know I would 😀
Thank you for the compliment, but I can't take all the credit. What you see is how it was when I bought it. I only added the wheels (came with the car) and tires. Besides, my hot rod pales in comparison to your beauty! Your photo captures it perfectly!
That photo technique is called 'light painting'. It's taken in complete darkness. you open the apeture on the camera for about 8 seconds while waving an LED light over a certain area. you repeat the process about 50 times and then layer the shots. takes a long time, but the result is sort of '3D'.
oldybutgoodie
September 21st, 2007 02:17 PM
