76 split bench fit 72
Old January 5th, 2019, 02:37 PM
Iceomatic's Avatar
I just need a seat that doesn't look like a dog chewed it up. I found a mint 76 split bench for cheap. Does anyone know if it will fit in my 72?
Iceomatic is offline
Old February 2nd, 2019, 01:08 AM
shiftbyear's Avatar
Can you ask the seller to measure the bolt holes front to back and side to side? It will at least let you know if it requires redrilling new holes.
shiftbyear is offline
Old February 2nd, 2019, 06:29 PM
Iceomatic's Avatar
I ended up getting it. It's been too cold to check it out. The 76 mounts won't work unless I come up with a leveling block or something (rear is a different height). Maybe I'll be able to use the original mount/track?
Hdmike444
June 10th, 2019 10:39 AM
stevengerard
September 3rd, 2018 09:35 AM
tpkj
May 6th, 2012 09:52 PM
68cutlassdriver
March 16th, 2011 06:20 PM
t bell
January 2nd, 2010 12:27 PM
Quick Reply: 76 split bench fit 72
