Vin number decoded
Vin number decoded
My son just aquired this car from his late grandfather ( was not his originally ), can any one decode the Vin so we know what we have ? Someone started a restoration of sorts and somethings just don't look right. TIA.
First off, that's not the VIN, that's the cowl tag. It was attached to the car by Fisher Body Works at Lansing Michigan. They built the body and installed the interior of the car before sending it to Lansing Final Production where the VIN was attached to the drivers side dash.
Your cowl tag decodes as follows:
ST69 - 1969 Model Production
3 - Oldsmobile division of GM
3667 - Style: Cutlass S convertible
LAN - Fisher Body Works Production
BDY 298498 - Body number assigned by FBW Lansing. Not related to VIN
PNT 57 P - Glade Green lower, Topaz upper
TRM 944 Gold interior
02C- Date build code: body and interior assembled during the 3rd week (C) of Feb (02) 1969
3687 - Style: Cutlass Holiday Coupe (pillar less)
Note: I made an ooops. You have a convertible not a Holiday coupe. I've amended my initial post to show that.
Your VIN is missing a number (the model year 9) It should read 336679M298122
There are a lot of duplication here, which is normal
3667 - Model Code: Cutlass S Convertible (V8)
M - Lansing Final Assembly
9 - Model year: 1969
298122 - Sequence on the Final production line at Lansing.
You may find broadcast cards in your car from FBW Lansing, but there won't be any build sheets. Lansing was fastidious about removing them as the car reached the end of the production line.
According to a 1969 SPECS book (Oldsmobile Salesman selling guide) the MSRP on your car was $3092.00
Just an info item, the production number of 298122 sounds huge, but remember that the production at each plant started at 100001. So your car was the 198,122nd car produced at Lansing that year.
In better perspective, here is the production numbers for 1969 Oldsmobile Cutlass S (boxed in red). The first column is price, second is production.
Actually, the "P" would have denoted the convertible top color. For the 1969 model year, there were only four colors offered: black, white (parchment), blue, and gold. Black and white were the only two recommended colors with Glade Green. I'm guessing the "P" stands for Parchment. Also, to clarify, TRM 944 is gold bench seat interior. This is interesting because the base interior in the Cutlass convertible was bucket seats; the bench was available as a credit option under RPO A52.
Joe, I looked at that page too. I did notice that on the line that says Glade Green the only available colors are White or Black - no other color available. Admittedly I did goof and incorrectly identify the car as a 3687 when it was clearly a 67 I looked in my other resources and couldn't find a P listing for the upper. The colors for vert tops I show are coded by numbers:
- White -1
- Black - 2
- Blue - 3
- Gold - 6
- White -1
- Black - 2
- Blue - 3
- Gold - 6
Well, my '69 PIM, section 0 page 183, shows a gold convertible top code of either P or 6 (shown in the PIM as P/6) and recommended for exterior colors of ebony black (10/A), sable (61/B), cameo white (50/C), topaz (65/G), aztec gold (75/J), palomino gold (63/S), or saffron (40/Y) only. The P still throws me, though. I've never seen that letter shown for a convertible top color on a '69 A-body until seeing it in the PIM. I'm kind of surprised it doesn't show glade green as a viable color for a gold convertible top.
Randy C.
Randy C.
Last edited by rcorrigan5; July 28th, 2018 at 04:02 PM. Reason: make the last sentence say what I wanted it to say
Randy C.
Randy C.
It was possible to order color combos other than recommended. I too thought the gold top with gold interior would look sharp on that green car. "P" for gold makes more sense here.
Sounds like the interior is still correct. The bottom color is no question Glade Green. This may be a special order car (since gold is not paired up with Glade Green anywhere in our documentation so far) , but I can't confirm that. It would however explain the coding for the top. I'd go with what Randy posted:
Well, my '69 PIM, section 0 page 183, shows a gold convertible top code of either P or 6 (shown in the PIM as P/6........ I'm kind of surprised it doesn't show glade green as a viable color for a gold convertible top.)
Those are RECOMMENDED color pairings. One could certainly order non-recommended color combinations. RPO Y68 is "Regular Paint Used With Trim Combinations Not Recommended By Paint & Trim Specifications Chart". The page below is from 1970 but these RPO codes were applicable in all years. And yes, I did notice the term "Special Car Order" on this page.
Well it appears the interior is not the same color as the car was born with. Upholstery should be gold. Another thing that stands out like a sore thumb are the seat belts. Those aren't even close to what the OEM ones look like.
To answer the question about the top - yes, very likely it was Topaz which is a gold color.
Joe?? Whuuuut? ME pull your chain Nebber.... I don't have that page from the 70 manual, thanks for the look see.
Now you're just doing that to pull my chain...
Sorry for all the questions, and with all do respect to all of you I'm not familiar with the terms, codes and so on as this is new to me. I'm A ford truck guy ( 73-79 specific ) I know nothing about this car which is why I'm here, to help my 18 year old son find out all we can about it. Again all the help is appreciated.
No worries, sometimes Joe just gets like that. It's his way of trying to get folks to study the posts that are made. I'm glad to hear you and your son are doing this project together. A blue oval guy eh? Gotta admit that I'm partial to their trucks. I did have a 78 3/4ton Custom that would do everything I needed except pass gas stations. I used it mostly to haul my camper. In the winter the trans tunnel generated so much heat I rarely needed the heater fan on more than low speed. That truck would start every time in any kind of weather, even -40.
Completely understood, but this is all new to me, it's a completely different language your speaking so forgive me if I don't understand or asking repeated questions. and speaking of questions i'm still confused on what the car would originally have for seats ?
TRM 944 is Gold bench seat car. RPO A52 Looks like this (Although the car shown is a 4 door, the seat color and fabric are correct) The actual design for a 69 Cutlass would look like the next picture showing the split uprights on the seat
#32
Joe?? Whuuuut? ME pull your chain D: Nebber.... I don't have that page from the 70 manual, thanks for the look see.
#33
#34
There's absolutely nothing wrong with just driving it and enjoying it the way it is. If you ever decide to just change the interior cover, there's a company called "Legendary Auto Interiors". They're top notch for interior restorations. They make everything from the door panels, headliners and seat covers. Here's a link to their .pdf catalogue for 69-72 Oldsmobile. The pattern on your car would be 'double diamond'.
http://www.legendaryautointeriors.co...ileCatalog.pdf
#35
The bucket seats (RPO A51) do look correct.
#36
PBatula
July 15th, 2017 09:23 AM
