22 inch rims
Old July 14th, 2018, 11:22 PM
Rosco920's Avatar
22 inch rims
All , i want to add 22 inch rims t my 72 vert. It seems that I’m having trouble finding rims for the bolt pattern. I also want to do a 22x8 in the front and 22x9 in the back. Is there a problem with this. Please don’t comment with the “those rims are too big” crap. It’s my car being fixed to my taste. I just have a simple uestion for those thatve been done the oversized wheel road. Any advice is greatly appreciated.
Rosco920 is offline
Old July 14th, 2018, 11:39 PM
svnt442's Avatar
It uses a standard 5 x 4 3/4 bolt pattern...same as many a donk. Not sure why you can't find anything. It could have to do more with clearance issues than anything else. If you are lifting the car then just look up the rims for a full size car with a 5 x 4 3/4 pattern and run with it.
svnt442 is offline
Old July 14th, 2018, 11:57 PM
Rosco920's Avatar
Cool thanks. What offset should I be aiming for.?
Rosco920 is offline
Old July 15th, 2018, 04:08 AM
svnt442's Avatar
You're going to have to do some measuring to see what will fit with the tire sizes that you want to run. The rear you should be alright because there is a ton of room back there. My guess would be with a 9" wheel that you should be able to get away with 4 1/2" or 5" of backspace...depending. It's the front you really need to worry about.
You need to find someone that has an offset tool something like this one:
That will make things a lot smoother.
svnt442 is offline
Old July 15th, 2018, 06:12 AM
Rosco920's Avatar
noted. Appreciate the help man.
Rosco920 is offline
Old July 15th, 2018, 10:14 AM
72 Olds CS
RetroRanger's Avatar
Someone (maybe Joe p) posted a home made version of that tool at one time I'll see if I can find it.....
RetroRanger is offline
Old July 17th, 2018, 06:01 PM
A real redneck engineering method would be to get a 26 inch wheel tire for a mountain bike from somewhere like walmart, then cut a strip of cardboard the right width and length to make the edge of the car tire when wrapped around the bike tire. Sheets of cardboard cut into circles, one for each side of the bike tire, could make the wheel, and you could build it solid in the center for the lugs, then add cardboard spacers or move the "tire cardboard" in or out for offset.
The wheel does not know or care that it is on an Olds, it just wants its pattern and enough room.
You going for normal big rims, or spinners, or sliders, or something else?
Koda is online now
Old July 18th, 2018, 01:32 AM
69 Ragtop's Avatar
...and here it is...
https://classicoldsmobile.com/forums...ment-tool.html
69 Ragtop is offline
Old July 18th, 2018, 05:57 AM
That's a cool tool Joe mentioned. Definitely measure it correctly with the right tool instead of guessing. I wouldn't want to end up scraping a tire against the fender with a wheel that was too big. Especially given the price of tires in that size.
Olds64 is offline
Old August 1st, 2018, 09:10 AM
brown7373's Avatar
Careful with the front. Years ago I ran slightly bigger tires on a Pontiac A body. Everything was fine until I pulled into the driveway. Wheels were cocked, the driveway was higher than the road and the top of the tire hit the top of the wheel opening and ripped the fender from the inner fender. Point being, the tire up/down travel needs measured when turning..
brown7373 is offline
86cutlass salon
February 17th, 2016 08:13 PM
scooter123
February 25th, 2012 09:44 PM
becken63
Wheels and Tires
May 27th, 2011 03:35 PM
D Appeldorn
January 12th, 2011 06:01 AM
easytobedead
February 1st, 2009 09:01 PM
Quick Reply: 22 inch rims
