Bench Seat Bracket? - ClassicOldsmobile.com
Bench Seat Bracket?
Old July 11th, 2018, 08:43 AM
Rosco920's Avatar
Bench Seat Bracket?
Hi - I have a 72 Cutlass vert and need some assistance on the bench seat. When I got the car, the person before me replaced the floor pans. I do not see any raised portion to mount the seats on. Was there ever a raised portion from the factory?
Like I stated earlier, I have bench seats and need to know how to mount them to the floor. Thanks for the help.
Rosco920 is offline
Old July 11th, 2018, 11:56 AM
2blu442's Avatar
Do you have a manual or power bench seat that you want to install?
John
2blu442 is online now
Old July 11th, 2018, 12:01 PM
Rosco920's Avatar
John
I believe the seat is manual.
Rosco920 is offline
Old July 11th, 2018, 12:17 PM
Ben
RAMBOW's Avatar
Bench seat just bolts to the floor pan directly. The factory holes go through the floor pan supports & have nuts welded to the bottom of them. If they did not drill out the holes when they installed the floors that may be why its hard to ID where they go.
Crawl under the car and look at the floor pan braces right where they meet the frame, you may have to use your fingers to feel where the nuts are. they were just little square nuts welded onto the brace.
Once you find them, use a hammer & punch to dimple the floor from the bottom through the center of the nuts, then you can drill out the floor pan in the exact spot so you'll be able to hit the nuts.
RAMBOW is offline
Old July 11th, 2018, 12:22 PM
2blu442's Avatar
I tried to find some pictures I could take for you. I've got a 1971 Cutlass with power bench, here's some pictures of where the front hole goes.
Old July 11th, 2018, 12:25 PM
2blu442's Avatar
Then here's the underside of a 1968 Cutlass floorpan. This car had bucket seats, but the outside seat rail should be in the same place as the bench seat rail. If the nuts aren't already welded to the floor pan I would suggest you get the front bolt in the right location, then set the adjustment rail on the floorpan and drill the back holes with the rail in place. Even though this is a 1968, the mounts would have the nuts welded to the underside and going through the floorpan plus pan support brace.
Front seat rail bolt hole
rear seat rail bolt holes
Rear seat rail bolt holes
Old July 11th, 2018, 12:30 PM
Rosco920's Avatar
You are a God send lol. Thanks man. I almost bout some floor tracks erroneously. This means that the bench seat does not move back and forth...I need to get buckets.
Rosco920 is offline
Old July 11th, 2018, 12:33 PM
2blu442's Avatar
The seat will move forward and back, so if you wanted to stay with the bench you could. The bottom of the rail is bolted to the floor pan. But the top of the rail bolts to the seat and will allow it to slide forward and back.
Ddbord
June 19th, 2012 03:08 PM
68Tom
May 8th, 2012 08:41 PM
Tony72Cutlass'S'
February 2nd, 2012 10:15 AM
68Tom
September 16th, 2010 11:41 AM
ctreutel
July 6th, 2009 04:21 PM
Quick Reply: Bench Seat Bracket?
Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
