1967 CS Holiday Coupe - Kick Panel Speakers
Old July 9th, 2018, 05:04 PM
babailey's Avatar
I purchased an aftermarket radio, new center speaker, and kick panel speakers from OPGI.
Radio - https://www.opgi.com/cutlass/1967/mo...nents/C240647/
Kick Panel Speakers - https://www.opgi.com/cutlass/1967/mo...nents/CH26869/
The passenger side kick panel speaker fits fine and sounds fine. However, the drivers side panel fits, but the speaker sits out too far and is impacted by the emergency brake.
My question; has anyone modified the emergency brake pedal so that it sits out a little farther.
I will be calling OPGI tomorrow to discuss the fitment issues as well.
babailey is offline
Old July 10th, 2018, 05:55 AM
edzolz's Avatar
The sales page specifically notes the driver side kick panel will interfer with the parking brake pedal. Maybe you could make standoffs to move the pedal out farther from the current mounting location without interfering with the other pedals.
edzolz is offline
Old July 10th, 2018, 07:33 AM
babailey's Avatar
Well crap, why didn't I pay attention to that?
I'm still considering options, I'll let everyone know what I end up with.
babailey is offline
Old July 10th, 2018, 07:45 AM
It depends on how much you need to move it. I've bent the whole assembly over a hair to clear. Or redrilled the front holes in the dash and physically moved it over a bit.
oldcutlass is offline
Old July 15th, 2018, 03:52 PM
babailey's Avatar
I was able to bend the assembly enough for the pedal to clear the speaker. I didn’t have to relocate anything.
babailey is offline
Old July 15th, 2018, 03:57 PM
Glad you got it.
Old July 16th, 2018, 07:15 AM
oddball's Avatar
Heh. Retrosound kicks + Infinity Kappa speakers (tall grill) + custom fuse panel (can't move the parking brake assembly) = ......
It'll buff right out.
oddball is offline
Old July 16th, 2018, 07:22 AM
What about rewelding it in a position the pedal will clear?
Old July 16th, 2018, 07:31 AM
babailey's Avatar
I like that mod, especially if I add metal back into that "V" via welding.
babailey is offline
Old July 16th, 2018, 10:42 AM
oddball's Avatar
The parking brake assembly can wiggle a little - maybe 1/2"? - as mounted, so very low profile speaker grills are probably fine. Modifying the entire unit would require removing it, which due to how I mounted a Autowire panel would be dramatically difficult at this point.
I replaced the main hinge rivet with a bolt and plastic washers a few years ago so it was much easier for me to remove the pedal and take the appropriate actions. That rivet was a real PITA, so I wouldn't attempt to drill it out with the unit mounted in the car.
babailey: yeah, this is going to get some quality time on the welding table.
oddball is offline
Gary's 2 442-S
September 6th, 2019 03:46 PM
rickbmac
April 22nd, 2017 02:36 PM
wcourt3010
January 20th, 2015 01:14 AM
keepitolds
April 16th, 2014 04:03 PM
fjross
August 21st, 2010 01:07 PM
Quick Reply: 1967 CS Holiday Coupe - Kick Panel Speakers
