'70 Cutlass Supreme Gas Tank
The tanks were installed "as is".....no paint, etc. The tanks have a plating or coating that adds some protection to the bare surface. Typically referred to as "Terne Plate".....made of a lead/tin mix.
If the car got DEALER-APPLIED undercoating then whoever shot the stuff under the car seemed to also spray the tank underside with the undercoat. I've seen that alot on dealer-undercoated Olds (and other Abody's) from our era.
Some people clean the new tanks and spray them with clear or you could use something like Boeshield T-9 (spray can applied wax/oil sealant) which can be reapplied periodically.
joemo
September 21st, 2022 04:47 AM
1carsick
October 17th, 2012 09:10 AM
Texas442
January 30th, 2012 05:36 PM
