LSD or Locking diff?
Hi, I have an open diff on my car. Every time i do a burnout i get one wheel spinning only. I'm thinking getting something to fix that. Should I get Limited Slip diff or should I get locking diff? What's the difference?
A limited slip uses clutches to slip the posi unit during turns when one wheel slower than the other. A locker has a mechanical device that locks the axles to one and other. Some lockers are pretty noisy in turns, and spool types are not conducive to having good street manners.
I vote for LSD over locker.
What car, and what rearend does it have under it currently? Some rears have a much larger selection of posi carriers than others.
When I was younger, I always chose the LSD when it was offered.
Oh, wait. You're talking about differentials.
Same advice. A lockup rear will make for a car that's only fun to drive straight ahead.
Some lockers are locked any time there is throttle applied, so making turns causes the inside wheel to slip, same as a spool. This can be VERY dangerous on wet / icy roads.
Not trying to make a 7min nurburgring car, but at least spin both wheels for burnouts.
Put up a want ad here for a limited slip rear, probably around 3.31.
You could use a '68-'72 rear from a different Division, if you want, but you may have to change the driveshaft, as there are several different ones, and they may have a different length at the nose.
If you want to see about getting parts to install in your rear, contact Monzaz on this board.
No such thing as 1:3-4 ish ratio. I think the standard no-cost rear in that year was 2.73:1 but could be 2.56:1.
If you are wanting lower gears as well as posi, I suggest looking for a complete rearend. If you are just swapping the carrier from open to posi, look for a factory limited slip differential. It's a lot easier to swap just the diff than it is to install new gears.
L77F85
Drivetrain/Differentials
March 19th, 2016 03:23 AM
CowsFlyTogether
September 11th, 2014 05:57 AM
