Transmission fluid?
Old February 19th, 2017, 07:36 AM
dddddyang's Avatar
Transmission fluid?
Hi I have a cutlass supreme with a 350 and turbo 350 trans (i believe so). The stock owner manual asks for DEXRON ATF for the fluid, but in the 70s it's the DEXRON II time. I saw mobile has DEXRON VI, will that work? Is it going to harm the trans or be beneficial for it since it's newer oil?
dddddyang is offline
Old February 19th, 2017, 08:44 AM
You won't harm anything. I typically use whatever is the cheapest Dexron compatible fluid from the local auto parts store.
Fun71 is offline
Old February 19th, 2017, 08:45 AM
Most ATF are backwards compatible.
oldcutlass is online now
Old February 19th, 2017, 08:47 AM
Anything that says "Dexron" on it should be fine.
MDchanic is offline
Old February 19th, 2017, 09:21 AM
svnt442's Avatar
You can still find dexron III. The dexron VI is synthetic. It won't harm anything to mix them, its just that the dexron VI costs more.
svnt442 is offline
Old February 19th, 2017, 11:27 AM
442Harv's Avatar
If you read the back of the bottle, it will say, to use in 2006and older, or the newer one says, for 2006,and newer. You want the one for the older. I think the newer one is sympathetic?
442Harv is offline
Old February 19th, 2017, 11:28 AM
dddddyang's Avatar
Yes the DEXRON VI is synthetic
Old February 19th, 2017, 10:19 PM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
I wouldn't recommend mixing synthetic Dex with standard Dex. Stick with standard dyno juice Dextron in this case.
droldsmorland is online now
Old February 19th, 2017, 10:52 PM
svnt442's Avatar
Sorry Dr....pet peeve.
There is no T in Dexron.
svnt442 is offline
Pookster6
October 31st, 2011 11:52 AM
gmacolton
March 22nd, 2010 06:41 AM
cfair
Brakes/Hydraulic Systems
June 8th, 2009 12:37 AM
asadebo
Alero
May 3rd, 2009 08:35 PM
American Lead
November 16th, 2008 04:10 PM
Quick Reply: Transmission fluid?
