Pics of my 72 Cutlass S
I took these yesterday and I thoughthink they looked cool.
Also, has anyone here put the quarter skins on their car? Do they come up as high as the vinyl top trim? Mines staying to rust there.
Thanks.
The grilles were installed by the original owner. They look better, more evil looking, than stock grilles. I do get some flack sometimes at car shows because it has a 442 grille in it like I'm trying to pass it off as a real 442 even though that's the only 442 emblem on the car.
Always curious on these - could you install a Cutlass emblem on them with little fanfare or do they not match up too close? No disrespect to anyone but '72's Supreme & S had the worst grilles out of the '70-72 IMO.
I don't think the emblems line up to good. When I restore it I'm going to change the exterior color to Antique Pewter and lose the vinyl top. I'm also going to shave all the emblems and put SSI wheels on it. But that's all a few years away.
With some finesse the cutlass ones can be made to fit. You've got to match the holes in the grilles up to the emblems and i don't think all the pins line up.
carefully placed double sided tape would be best,i think.
But who cares what other people think.
I dig the green color,and the vinyl top. BTJM.
I have a repop skin that's been floating around with me for years.
The panel comes up to the point of the rear window and carries up a little higher to the rear. I'm sure it'll cover the vinyl trim seam.
It DOES NOT go up as high as the original panel/roof seam
Did you have to drill different holes to mount that on the repro grill?
I think it was lowered or the springs are wore out. It bottoms out on everything. I've been putting off rebuilding the suspension. It's due though.
It has one repaint. The original color is Pinehurst green. When it was repainted they got the color to light. All of the jams are still original green though. I'm still torn on if I'll repaint it green again.
not original.
Oldsprepp
April 3rd, 2008 06:20 AM
kylem4711
December 19th, 2007 02:53 PM
