Column to floor shifter Conversion
Hello i am going to switch from a column shifter to a floor shifter at the same time I switch out the jetaway for a TH350. I just want to make sure I have everything that I need to make the switch from column to floor.
1. Center console (mini)
2. Shifter I have a dual gate (69 GTO)
3. Neutral safety/back up switch
4. Bracket to mount shift and console
5. Shifter cable
That is what I have now am I forgetting something? I read somewhere and it said a wire hardness? Do I need this or can I just use the wires I have now?
pj
5. Shifter cable
pj
you forgot TH350 transmission, LOL.
in all seriouslness, make sure you get correct sized shaft on the tranny so you can use your factory driveshaft. i believe you need a short shaft....
oh, and i mounted a tac where the column shifter use to be, it worked perfectly, check it out:
Just grind off the nub from the shifter, finish it, paint, and mount the tach where you can see it locking the coller in park. Also add a floor shift speedometer and done. Otherwise, find a floor shift column.
Bitburger
December 30th, 2012 04:49 PM
