72 choke stove
72 choke stove
What is this crust on the choke stove tubes? Also, the new replacement stove I have is smaller in length than this original one. Will it matter?
Classic example of a redox reaction (reduction-oxidation) where oxygen robs iron of electrons - forming rust. If this is the first time the stove-pipe has been replaced in 46 years, it should be expected to show plenty of rust. I replaced mine and it demonstrated the same rust. I believe my replacement was the same size as the original (I ordered from ILT). Did you order the correct replacement? Assuming you did, I doubt a very minor difference in size would be significant.
- Interesting, thanks.
- My replacement was from Fusick. Looking at all the other parts folks, including ILT, they all appear to be the smaller/shorter version. Must not be a big issue apparently.
So you are correct, it's not a big issue.
It's a metal tube sitting in the flow of 1100ºF exhaust gases, so a couple inches shorter isn't going to make much of a difference on the temperature of the air being drawn out of it and across the bimetallic spring in the choke housing.
